Circuit Diagram in AutoCad format
Howard_B
Re: Circuit Diagram in AutoCad format
Postby Howard_B » 26 May 2017 09:49
Links to PDF copies of final drawings covering lighting circuits, windscreen wiper/washer & flasher/hazards circuits. Link to earlier sketch has been cancelled
https://drive.google.com/open?id=0B0OCjgNgn85aaHl0b3lDTi1kbVE
https://drive.google.com/open?id=0B0OCjgNgn85aem1SSVQ3cjJJZkk
Balance to follow during June along with the AutoCAD dwg file
Howard
Howard_B
Circuit Diagram in AutoCad format NOW AVAILABLE
Postby Howard_B » 03 Jun 2017 07:11
I have completed the drawings and they can be downloaded from the following link:-
https://drive.google.com/open?id=0B0OCjgNgn85aLXNqT29uMExBSmM
The folder includes:-
1) TR7 wiring diagram Rev 1.dwg
(Produced using Draftsight, so you will get a warning message when opening which can be ignored. Contact me if you need a copy in a different version of AutoCAD)
(This must be saved in the same folder as the TR7 wiring diagram because it is embedded sheet 1)
3) TR7 1980 wiring diagram.pdf & TR7 1980 wiring diagram key.pdf
(This is from the paper copy of the workshop manual that came with my car and includes most of the 1981 changes. The manuals I found on the web are for older versions)
A couple of points to be noted:-
A) There is an intermittent wipe function on my wipers, but there is no information in my manual so it is missing from these drawings.
B) The original drawings show detail changes in wiring & wire colours. I have noted some wiring changes on the drawings but this is not a complete list so you need to check your car.
Howard
Howard_B
Postby Howard_B » 03 Jun 2017 12:59
oliviertr7
Postby oliviertr7 » 17 Mar 2018 10:04
hello howard
I am currently restoring a harness on my tr7, I allowed myself to download your file in pdf, thank you
Olivier
allzway
Postby allzway » 23 Mar 2018 15:25
Nice work.. that is a pretty tough job.
