Clock stopped working
Postby UKPhilTR7 » 20 Feb 2008 06:54
<font color="green"><b>Not so long ago, I put a flashing LED in the dash and connected it to the cigerett lighter. Since then the clock on my dash has stopped working. Putting 1 and 1 together I have come up with 2, but can anyone confirm if the clock is also connected to the cigerett lighter and if it is likerly that when connecting the LED, I have knocked the clock wire?</b></font id="green">
Postby John Clancy » 20 Feb 2008 10:09
The TR7 clock is notorious for just packing up. If you take it out and give it a bit of a bang you'll probably find it comes back to life... but only for a while!!!
Steve-LPS-Thomas
Postby Steve-LPS-Thomas » 20 Feb 2008 10:18
Sometimes my clock works, often it doesnt..actually had both clocks in both cars working at the same time recently!
<ul><b><li>Ex BL Development TR8 (Rally Replica).</li>
<li>The First and Only UK TR7 "Victory Edition" (Now Sold) </li>
<li>Ex-BL/Safety Devices Development 8v Rally Car.</li>
<li>"The Shape of things to Come" Trailer.</b></li></ul> Image
Rblackadar
Postby Rblackadar » 20 Feb 2008 10:54
Try disconnecting the battery for a while. I had a "broken" one when I got the car but when I disconnected the battery and reconnected it the next day....voila it worked.....I don't know man, It's friggin British.
Graham Robertson
Postby Graham Robertson » 20 Feb 2008 12:08
I tightened the earth strap from the battery, and later noticed my clock had come to life! (who looks at the time anyway, when you're driving a TR7?!)
1977 TR7 FHC Flamenco Red
RJS
Postby RJS » 20 Feb 2008 13:30
I have owned three clocks for my car. All of them have worked "some of the time".
Last weekend I broke down and put an oil pressure gauge in their place. I think I will be much happier now.
Rob
Postby UKPhilTR7 » 20 Feb 2008 13:34
<font color="green"><b>I must admit that this is the first time that she has played up in the 4 years that I have had her. But I do like the idea of the oil pressure switch in her place.</b></font id="green">
1980dhc
Postby 1980dhc » 20 Feb 2008 16:19
My clock used to work only when I was having a problem with my voltage regulator. The first time it happened I had no idea why the clock just started working, the second time I recognized the problem and got it fixed much quicker.
Postby paul w » 20 Feb 2008 18:17
When my clock stopped,i thought i'd try electro shock therapy treatment on
it! I took it out and zapped it with 12 volts clean and it started immediately. Has'nt stopped since!
danny
Postby danny » 20 Feb 2008 18:37
My advice is bin the clock and fit an oil pressure gauge.
It's a really easy job to fit an oil pressure gauge, I fitted one to my car and have done a technical article on the procedure, just click on the link.
http://www.waringstowntr7s.co.uk/oilgauge.htm
Danny
1980 TR7 fhc Brooklands green
1967 Spitfire Mk3 Signal red
Postby Odd » 20 Feb 2008 18:50
I think you guys should hold your horses some here...
There's a solution for the erratic operation of the Wedge clock being tested just as we write this.
A guy over in America have come up with a clever fix for this. I now have a 'fixed' clock in my '8,
as have Jim TenCate in NewMexico, and there will be an article published in the next issue of the
TR8CCA newsletter giving all the details.
My clock have been tested (operating off of a simple 9V alkaline battery no less!) in the freezer,
in the fridge and in ordinary indoor temperatures for several days at a time - and it <u>never</u> stopped!
Now back in the car it keeps time almost to the second! A single, or maybe two, minutes off in
a week. That good it wasn't even when new...
You will be able to read it all as soon as the article is published,
I guarrantee you will be delighted over the simplicity of Gregs reworked electronics.
RJS
Postby RJS » 20 Feb 2008 19:35
To be honest, I would have changed over to the oil pressure gauge even if the clock worked all the time. I just like having it better than having a clock.
As with almost every change I have made to my car, I have either saved the old parts that were removed, or have spares (I have an extra instument panel in this case). Maybe someday someone will want to take my car back to stock someday.
Rob
Postby saabfast » 20 Feb 2008 20:13
Unusual I know but I happen to like a clock in my car. Mine stopped working last autumn. I recently had the dash apart to replace the (non working) instrument lighting with LED bulbs (as a side issue why do white LEDs shine blue through a green lens???).
While the dash was in pieces I had a number of trials to get the bulbs working, connecting the battery each time. Lo and behold the clock started working again. Put the whole lot back together and switched on - lights work but the clock has stopped again!
Odd, is there a copyright on the method or is it available to thoses of us who don't belong to the TR8CCA, which I assume is an american organisation?
RJS
Postby RJS » 20 Feb 2008 20:55
Try this to fix the clock. Might be a little involved, but could give you a few ideas.
http://www.smallscalerailway.com/tr7_clock.htm
Postby stevie_a » 20 Feb 2008 20:58
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Rblackadar</i>
<font color="blue"><b>Try disconnecting the battery for a while. I had a "broken" one when I got the car but when I disconnected the battery and reconnected it the next day....voila it worked.....I don't know man, It's friggin British.</b></font id="blue">
<font color="purple"><b>That is what i did
and it is still working</b></font id="purple">
Image Image Image
