INDICATORS
higgie
INDICATORS
Postby higgie » 07 May 2008 12:43
Can anyone help i have the following issue with my TR:-
The LHS turn indicator works but flashes very slow
The RHS turn indicator comes on and stays on without flashing
The hazards work fine
Do i have change the flasher unit?
Thanks in advance
Higgie
trphil
Postby trphil » 07 May 2008 13:18
Changing to a modern flasher unit will probably solve the problem but the actual reason will be due dodgy connections/earths and obviously dodgier on the right! Are you sure you haven't got a bulb blown on that side?
black_1980_tr7
Postby black_1980_tr7 » 07 May 2008 17:38
When the right turn indicator stays ON, does the front bumper lamp
(amber) and rear tail light assembly lamp also illuminate?
If yes, then change the turn indicator flasher relay. The hazard
flasher is a separate relay. Also, check to make sure the rear
tail lamp assembly has a good sheet metal Ground connection.
[:p]
mb4tim
Postby mb4tim » 08 May 2008 00:45
gairo1
Postby gairo1 » 08 May 2008 05:53
I second the idea to change the relay.
Very easy, even I managed it! My TR7 Sprint had the same issue
Cheers, Jerry
higgie
Postby higgie » 08 May 2008 06:47
Thank you all for your comments particulary the issue of the tail light coming on when the indicators are on. As i have just put the car back together I will check for a sound earth and also change the flasher unit. Keep you posted.
Higgie
Users browsing this forum: No registered users and 128 guests
