Sticking door
Graham Robertson
Sticking door
Postby Graham Robertson » 05 May 2008 16:43
My drivers side door has been sticking for a while. Luckily today I noticed something on the garage floor which turned out to be the bottom door pin from the top hinge. I managed to push the pin back in easily enough, and tapped it in with a hammer and punch. The door is now better, but does anyone know how I can prevent the pin from working loose and falling out again?
1977 TR7 FHC Flamenco Red
Postby Chris Turner » 05 May 2008 17:31
It is a common fault with Speke built cars, I need to tap the pin back in on my early FHC or else it works loose. Perhaps a spot of weld will hold it in place.
www.triumphtr.co.uk
TR8 FHC
Graham Robertson
Postby Graham Robertson » 05 May 2008 19:46
Thanks. I might just by a spare to be ready just in case the pin falls out again and I loose it.
danny
Postby danny » 05 May 2008 20:31
Hi Graham,
You could apply LOCKTITE thread lock/seal to the pin and then knock it in.
Danny
1980 TR7 fhc Brooklands green
1967 Spitfire Mk3 Signal red
Users browsing this forum: No registered users and 112 guests
