cable
darwin
cable
Postby darwin » 05 Apr 2008 17:26
I have found a cable with a pull/push knob on it with,I think,the letters o.r.g. on it.It is close to thr heater etc.
Can you tell me what it is?
Thanks
gb
Postby Beans » 05 Apr 2008 19:48
If it looks like the knob you'll see on the right under the radio, it's a A/C switch.
Otherwise it'll probably an after market item.
Edit ... the original knob doesn't have o.r.g. on it, it has the text "PULL ON", so i'd put my money on an aftermarket installation for ???
Johnluss
Postby Johnluss » 06 Apr 2008 01:20
Hi Beans.
What are those blue seats on your TR7?
Thanks
Postby Beans » 06 Apr 2008 08:40
Sparco Evo's
darwin
Postby darwin » 06 Apr 2008 09:18
Hello,
Thanks for your suggestion Beans but it is not the airco switch its a small ,almost diagonal shape knob which came loose when i removed the heater control panel.The "bowden"cable goes somewhere to the back of the heater unit and when pulled or pushed it sounds like a vent closing/opening.<font color="black"></font id="black"><font color="black"></font id="black"><font color="black"></font id="black">
gb
darwin
Postby darwin » 06 Apr 2008 09:19
Sorry,read diamond shape , not diagonal.
gb
colonel bogey
Postby colonel bogey » 06 Apr 2008 10:12
Hi Darwin,
If you can try and upload a picture for us,maybe we'll have more luck identifying it for you [:)]
Greg
'76 TR7 FHC Auto Java Green
"Colonel Bogey"
Postby Beans » 06 Apr 2008 15:59
Sounds like one of the original rod linkages from the heater was replaced by this cable somewhere in it's earlier life.
There should be no cables on a TR7 heater ...
