Headlight Squeal
kermit
Headlight Squeal
Postby kermit » 19 Feb 2008 00:41
Today I was able to replace the headlight assembly that was not working with one that I had bought off fleabay 5 or 6 years ago. The motor on my original unit would not move and the manual knob would not raise the pod.
The good news... The pods now raise & lower together as they are supposed to [:D].
The bad news... The assembly that was replaced makes a squealing noise when the pods are switched to raise or lower. The noise is not coming from relays but from the assembly [B)].
Could it be the units need to be lubricated? If so, what type & brand of lubrication.
I am hoping that I didn't get screwed by the ebay seller.
Thanks
Thanks
80 TR7 DHC with ZS Carbs
Brooklands Green
Postby Rich in Vancouver » 19 Feb 2008 01:18
If it is going up and down you are well on your way. After having them sit for years I wouldn't be inclined to claim that the seller fleeced me either.
I would take a can of a quality lubricant (I use "Tri-Flow", Excellent stuff) and give all of the pivot points a good spray for two or three days in a row. If your noise is coming from dry joints that should help.
Good Luck,
Rich
Postby TR Tony » 19 Feb 2008 10:34
I had this from one of my headlights a while ago. I used some spray grease on the moving parts of the mounting assembly & it has been quiet ever since.
Postby john 215 » 19 Feb 2008 21:28
One of mine got noisy a few years ago [V] i to used Tri Flow, at the time we were using at work for Rover 800 door barrels (tech bulletin rec using it) bl88dy great stuff.Could'nt find a supply over here for ages till i noticed some for sale in cycle shop! Apprently mountain bikers use the stuff, lubricates but crud does not tend to stick to it [^]
Postby Hasbeen » 19 Feb 2008 21:38
Gee kermit, if you're going to make a couple of TR7 head lights do
something they just hate doing, [go up & down, & do it together],
you've got to expect them to bitch about it, at least for a while.
kermit
Postby kermit » 20 Feb 2008 01:24
Thanks guys... I went to my garage tonight and actually found a bottle of the triflow that I had bought many years ago for the chain on my mountain bike. The stuff worked really good on the bike. so good that the bottle was empty.
I will track some down and let you know if it does the trick.
Hasbeen - my tr tends to do a lot of bitchin [}:)]. Yet I still am obsessed with it...
Scott
Brooklands Green
Users browsing this forum: No registered users and 122 guests
