Roll Over Bar.
Roll Over Bar.
Postby john 215 » 17 Feb 2008 14:14
Hi Ladies And Gents,
Brought this of Fleabay about a year ago for a bargain price, gent i brought it of said it was supplied by S+S Prep. Getting near to the point when i will be fitting this. Problem being no instructions [:(] Now i know it, that as men we dont read instructions [:0] but when your good woman isnt looking most of us will sneak a quick look [;)] Has anyone ever fitted one [?] do i have to drill my own holes or do use anything already there [?]
Type of frame i have-
Detail of side mount-
Detail of top mount
Thanks in advance for any tips,
Cheers John.
Postby paul w » 17 Feb 2008 18:21
John,i aint got any distructions either!!But you are welcome to have
a butchers at my rollbar to take measurements etc.
Steve @ SandS
Postby Steve @ SandS » 17 Feb 2008 20:40
John, give me a ring and I'll talk you through it
Steve @ S&S Preparations
Postby john 215 » 17 Feb 2008 20:48
Hi Steve
Your a gent sir [:D] Will call towards the end of the week as not doing it till next weekend and will probaly forget half what you tell me in between!!! Thanks for the offer Paul, meant to have a good look yesterday and suprise suprise forgot [:p]
Postby john 215 » 21 Feb 2008 20:17
Spoke to Steve today, what a top bloke [:D] explained everything better than the written word!! Thanks again Steve if you read this, if you ever need any BMW info dont hesitate to contact me.There realy are some top people involved in this 'hobby' of ours [:D]
Cheers John.
Postby busheytrader » 25 Feb 2008 09:25
John,
Agreed about the guys at S & S. Just wish they weren't so far away.
I always fancied a roll bar. I'm close to 6'2" so have the seat a far way back. Does the roll bar restrict the seat movement at all?
Many years ago I bought a smart blue tonneau cover from S & S. Have you had to cut yours around the roll bar mountings?
Postby john 215 » 25 Feb 2008 17:39
Hi Adam,
Will let you know about the hight thing when i put the seats back in at the weekend i am 6 feet plus in my heals [:0]!,got mine of fleabay way less than half price and still in wrapper. Easy to fit except one bolt that mounts on rear deck,cant get to put a nut on as fuel tank in the way [V] [:(!] Will have to work on that one and it wont invole taking tank out!!
I beleive you need to 'adapt' the tonneua cover but mine is well past its best so will replace it with one already cut.
As for guys at S+S cant fault them as you wish they were closer,200+ miles is a long way for a natter on a Saturday morning!
Postby paul w » 25 Feb 2008 17:41
Adam,my bar does'nt restrict seat movement at all.You will have to
buy a shaped cover unless your good with scissors and needles!
The downside to fitting one,is that it restricts rear vision,esp.
with hood up.
Ianftr8
Postby Ianftr8 » 28 Feb 2008 08:32
John,
I have the same roll bar fitted to my 8, I have made a couple of changes to the mounting, Ie welded in captive nuts for the lower mounting area. If it helps you are very welcome to look at mine I am based in Essex.
Ian
Ian Freeman
1979 TR8 DHC California car that never crossed the pond
1962 Triumph Courier
Postby john 215 » 28 Feb 2008 16:56
Hi Ian,
Thank you very much for the offer [:D] That is exactly how Steve from S+S Prep told me to do it. Had a good long look at it and decide rather than weld used 'rivnuts' instead, if anyone not sure what they are then click on the link-
http://www.merlinmotorsport.co.uk/FASTE ... index.html
I have had a gun for ages and supply of rivnuts that we use at work, guess i am getting lazy in my old age [^] but seamed easyier than welding and grinding.
Guess how the one which requires the tank to be removed will be held in[?] Yep rivnut!!
Once again Ian thank you very much for the offer and would love to see your cars sometime anyway.
Cheers John.
Ianftr8
Postby Ianftr8 » 28 Feb 2008 17:38
Great,
Rivnuts are a really good way and you have saved so much time by not having to take the tank out!! - although If you do take the tank out at any time I would beef up the area area under the parcel shelf just in case you do need to use the Rollbar for what it is designed to do, this will just give a bit more strength.
You have helped me too - I have been looking for somebody who supplies heatproof covering for wiring (where the mains cable from the battery to the starter motor runs very close to the exhaust pipes) they have some stuff that will do just the job!
I think the rollbars look really good when fitted and they help to stiffen up the car a little too.
Ian
Ian Freeman
Postby john 215 » 28 Feb 2008 20:07
Hi Ian,
Good point [:D] will do. Merlinmotorsport are top guys to deal with very helpful and quick delivery, have had lots of parts of them lately and no problems.
Cheers John.
welshsteve
Postby welshsteve » 28 Feb 2008 20:12
What size rivnuts are you using John?
Cheers Steve
If it's got tits or tyres then it's gonna cost ya!
Postby john 215 » 28 Feb 2008 20:50
Hi Steve,
The rivnuts i used on the side are 8mm thread size (get them from work) fitted with stainless steel bolts.The nuts and bolts on the rear deck are 10mm also stainless.
Just found this place they seem to carry a good range-
http://www.bazaarbuilder.com/cgi-bin/in ... t=instoneb
Cheers John.
Users browsing this forum: No registered users and 129 guests
