15" wheels offset and diameter??!
ponyboyone
Postby ponyboyone » 03 Feb 2008 16:23
Ok we are going to break down and buy two front wheels for our fabulous race car http://www.petepaulsen.com/Catalogofwheels/Circle%20Track%20Wheels.htm my question is what is the max diameter and correct offset for the 205-45, or 215-45 tires to fit our 1976 TR7 coupe?
Chris
80 spider
76 coupe
http://scratchybottom.blogspot.com/
Postby bmcecosse » 03 Feb 2008 18:40
15" wheels are surprisingly 15" diameter! Does your car still have the standard hubs with the 3.75" PCD ? Not many wheels made to fit that size. However MGF wheels happen to fit very nicely - although you probably need to buy them in UK since I don't think MGF ever made it across the Atlantic. Dunno why - but if it had i'm sure MG would still be alive and kicking today.
jeffremj
Postby jeffremj » 03 Feb 2008 20:55
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">My question is what is the max diameter and correct offset for the 205-45, or 215-45 tires to fit our 1976 TR7 coupe<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">Go here and check for yourself that 16" is correct for your tyre sizing to give the same rolling radius:
http://www.tyresave.co.uk/tyresize.html
The original size is 185/70x13. I have 7" wide wheels with ET10 offset. These are OK at the front, but need the rear wheel arch lip removing.
ponyboyone
Postby ponyboyone » 03 Feb 2008 23:47
Paulsen wheelshttp://www.petepaulsen.comwill custom make steel wheels for $39 each, raw (not painted).So 7" wide in the front will work with ET10 offset? What is ET10? We have a Ford 9" diff. in back so wheels should not be a problem to find, but we still plan to fold the rear wheels arch lip.
Thanks
Chris
