Brake switch washer position?
bonnietiler
Postby bonnietiler » 12 Jul 2020 17:38
I have lost both rear brake lights, I have removed the switch under the brake pedal and cleaned it to little effect, I replaced same and not altogether surprisingly had exactly the same result, nothing, I have ordered a new switch but when mine came off , it kind of fell off and I notice an interesting washer with a rebate on one side, I'm assuming that the nut sits on top of this but which way round does the rebate go?
Many thanks
Brian
Re: Brake switch washer position?
Postby saabfast » 12 Jul 2020 18:20
Not sure of the answer to your question (can't remember now) but they are known for the bracket bending and hence either stopping them working or making them on full time. I had the latter after doing some work around the pedal area when I must have leant on it somehow, a simple bend back corrected it.
Postby Beans » 12 Jul 2020 19:24
I use a "modern" replacement which is a direct fit for my cars. Info in the link below
https://tr7beans.blogspot.com/2020/02/new-brake-light-switch.html
oliviertr7
Postby oliviertr7 » 13 Jul 2020 19:21
excellent beans, good to know
Users browsing this forum: No registered users and 104 guests
