as the title says what are they and do I need them???
https://rimmerbros.com/Item--i-TKC3300URFK
Beans wrote:If the springs fall out the car is lowered far to much, or the rear dampers are to long
The only Triumphtune fronts with dual rate were already very low! I went for the less lowered single rate and they are still OK 20 plus years later. IMO, this is as low as 'necessary' on a TR7/8:busheytrader wrote:The front (yellow/ green) sagged considerably over 30 years, the car was hitting the much shorter than standard Triumph-tune bump stops on almost all potholes and speed bumps.
Users browsing this forum: No registered users and 23 guests
