Suspension Ball Joint Thread Size
Sondar
Postby Sondar » 22 Dec 2017 10:34
Hi All,
Merry Christmas & all that...!
Back to important stuff (!), can anyone tell me the thread size and pitch for the control arm ball joint? I'm in the process of replacing the shocks and springs & have managed to lose the nuts for the ball joints. Nothing quite seems to fit, but at least if I know the correct thread, I should be able to sort it out.
Should be more careful and organised I know, but it's one of those jobs that started out as a weekend project but turned into several weeks due to warranty delays on the replacement shocks and then deciding to change spring rates...
Any help much appreciated, as usual!
Sondar
1980 TR7V8 in Poseidon Green - 4.6 Rover V8, limited slip diff, front coil-overs, AP Racing 4-pot front brakes, leather interior. Last of 8 owners, mine since 1999 and no-one else is getting it...
supercass
Re: Suspension Ball Joint Thread Size
Postby supercass » 22 Dec 2017 12:15
What brand of shocks did you have warranty problems with?
supercass
darrellw
Postby darrellw » 22 Dec 2017 21:46
According to the ROM, it should be 1/2" UNF (1/2"-20).
Darrell Walker
66 TR4A IRS-SC CTC67956L
81 TR8 SATPZ458XBA406206
Vancouver, WA, USA
Sondar
Postby Sondar » 22 Dec 2017 21:55
It was a GAZ shock - replaced under warranty after 18 months.
I thought it would be 1/2 inch UNF too, but apparently it isn't (I tried a brand new nut yesterday). Actually got an existing nut on there this morning. Not sure what size it is, but possibly an M12 125. I lifted the arm a bit higher with the trolley jack to give it more resistance to turning in the joint & it went on with a little resistance.
Should have thought of that earlier...
Sondar
Postby dursleyman » 23 Dec 2017 14:18
Pretty sure I have had different size nuts on different cars I have worked on. Why doesn't that surprise me?
Must go and check the spares in the garage now!
alc59
Postby alc59 » 23 Dec 2017 16:49
My 1980 DHC has 1/2 UNF nyloc nuts. Easy to find on ebay
Happy Xmas
Al
Users browsing this forum: No registered users and 127 guests
