Master Cylinder P. D. W. A shuttle problem
lgray001
Postby lgray001 » 15 Nov 2016 06:28
I'm trying to rebuild one of the two master cylinders I have, but I can't get the P. D. W. A. shuttle removed on either one of them to replace the O-Rings.
Does anyone have a suggestion on how to get it out?
Stag76
Re: Master Cylinder P. D. W. A shuttle problem
Postby Stag76 » 15 Nov 2016 06:53
There's a small pin hidden under the rubber insert in the forward reservoir mounting point
that locates the piston.
You can pull it out easily with pliers or similar, and that allows the piston to be removed.
Stag76
Postby Stag76 » 15 Nov 2016 07:08
Sorry, I may have told you something you didn't need to know.
Are you trying to dismantle the master cylinder, or the proportioning valve mounted on the inner guard?
If it's the valve you're working on, please disregard my previous post.
Postby FI Spyder » 15 Nov 2016 15:13
I'm assuming you mean the small piston that operates the brake failure switch. As it doesn't move (except during a failure) it tends to get frozen in position on almost every brake cylinder. There is a high cam that the switch rides on, I got a larger screwdriver in there to lever the piston free after which the piston came out quite easily. Probably wouldn't hurt to load it up with penetrating oil and let it sit for a couple of days before trying. After overhaul and installation, don't put the switch in until everything is adjusted and working (system bled).
Users browsing this forum: No registered users and 119 guests
