Wipers fault fixed
Wipers fault fixed
Postby dursleyman » 02 Jan 2015 19:28
My wipers and the washers packed up on the new car which was annoying. They worked fine for the recent MOT then nothing when I needed them last week. Now I have had time for a look and found the problem so thought I would share it with you. You will laugh so best sit down.
It was just wipers and washers not working but everything else on the car worked fine (even the headlights go up and down on request). The symptoms pointed me towards the column switch being faulty and the pictures below show what I found.
The problem was caused by me tidying up the wiring with a cable tie and then the clamp bolt on the column had chopped the wiper switch tail when the steering turned. I thought I was being neat but all I did was to cause the problem.
1981 TR7 Sprint DHC
Postby stevie_a » 02 Jan 2015 19:39
<font color="teal"><b>Schoold boy error</b></font id="teal">...[:D]
Image ImageImageImagehttp://www.smallbiztranscripts.co.uk
Postby dursleyman » 02 Jan 2015 20:16
Absolutely, I feel like a right plonker.
1981 TR7 Sprint DHC
Postby FI Spyder » 02 Jan 2015 21:33
You'd be surprised at how many new cars had that problem (wires under the dash) right from the factory. The only recall my '71 Javelin had. New car owners should be so lucky.
Triumph TR7V8 coupé
Postby Triumph TR7V8 coupé » 03 Jan 2015 14:18
Made exactly the same mistake a few years ago with the same result only I did hear mine snap.
J.
Postby Hasbeen » 03 Jan 2015 22:48
One of my 7s, just after I'd bought it had the column pick up the speedo cable, & start to wind it around itself. Fortunately there was enough extra resistance for me to realise something was wrong, & stop turning the wheel before checking & finding the problem.
Users browsing this forum: No registered users and 356 guests
