REAR SUSPENSION DAMPERS
j.johnson23
Postby j.johnson23 » 11 Apr 2013 06:56
Does anyone have a rear damper to hand to measure the extended and contracted lengths?
Asking as If I order lowered springs I don`t want dampers bottoming out and want to see if there is an alternative.
Cheers.
Benzo
Postby Benzo » 11 Apr 2013 09:16
If you are going to buy new shocks and springs you may as well Get some of Hamilton classic avo rear Coilovers.
Currently back to Basics with my BMW V8 Engined Build.
Postby Beans » 12 Apr 2013 22:08
No damper to hand at the moment, but surely something to bear in mind ...
http://tr7beans.blogspot.nl/2007/07/rear-damper-problems.html
Postby FI Spyder » 12 Apr 2013 23:29
Could be a little disconcerting to know the car is bottoming out on the shock and not the bump stop. Have you received any word from AVO as to why the recommended shock for the TR7 is too long?
Postby Beans » 13 Apr 2013 17:56
I didn't bother as I got a set of brand new Koni's at the time ...
As for the measurements, taken from a proven set of Koni's;
• Fully compressed ± 305mm
• Fully extended ± 495mm
Both measurements taken between the retaining rings for the rubber bushes
Users browsing this forum: No registered users and 164 guests
