Contact for Raider? user on here?
Benzo
Postby Benzo » 07 Mar 2013 14:53
http://raidertr7.blogspot.co.uk/search/label/Brakes
Is this person a user on here? want to pick his brains about his AP brake setup in his blog.
I need some Alloy bells made up too like he has.
Currently back to Basics with my BMW V8 Engined Build.
Postby Beans » 07 Mar 2013 16:21
PM him on the CT forum, he's much more active there.
Benzo
Postby Benzo » 07 Mar 2013 17:38
Thanks!
tr8coupe
Postby tr8coupe » 07 Mar 2013 18:19
[:D]fantastic set up that is big big money about 2 k per side [:D]just calipers bells discs pads
and hub similar as on mk2 escorts monte carlo set up [:D]
look on the bay plenty can give you ref number
BMW Z1 ( sold)
Westfield sport carbon (sold)
Eurosport x1/9 turbo (sold)
TR8 coupe
Ginetta G27
TR7 v8 monster on 245 tyres all round (sold)
TVR VIXEN (sold)
Alfa GTV 3.0 CUP lol
Benzo
Postby Benzo » 10 Mar 2013 13:46
My car obviously with the engine choice is never going to be an historic rally car, so i dont need to go for the monte carlos.
I am interested in some of the more modern open back 5000 radial mount series. These are about £400 a caliper, which i'm happy enough to pay.
I just wanted to know if there was an off the shelf kit, anyone had made up bells or had some dont before because if i could but bells i could mount the caliper to suit.
Anyone any other information for me?
Im keen to go AP.. Im not sold on the wilwood or HiSpec kits.
Postby dursleyman » 10 Mar 2013 15:30
Beans, you do have to be a bit careful with bells. I got given some really nice big AP radial calipers and discs off the Mitsubishi WRC cars in 1992 (they threw them away after a couple of events) and we made some lovely aluminium bells to use them on my Cossie.
However, on day two at 24hrs of Ieper one of the front discs broke which made us a bit nervous for the rest of the day.
We identified the problem afterwards as being caused by the heat build-up and different expansion between the aluminium and the steel disc.
Found some proper AP bells (Mitsubishi freebie again) and machined them to Ford spacing. The AP bells were much thinner than ours and had diagonal slots between the 12 disc bolts to allow movement. No further problems.
I still have the disc (sorry Hasbeen) and I'll put a picture in my Black Museum for you.
1980 TR7 Sprint DHC
tr8coupe
Postby tr8coupe » 10 Mar 2013 17:20
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Benzo</i>
y not brembo from a fiat coupe they are 4 pot and vented and pcd very very close to tr7
BMW Z1 ( sold)
TR8 coupe
Ginetta G27
TVR VIXEN (sold)
Benzo
Postby Benzo » 10 Mar 2013 18:52
Have you seen a set installed before? I used to own a 20vt coupe so I am familiar with the setup,
Can anyone tell me what the disc pattern is on the tr7? The same as the PCD? Dispite being mounted on the back of the hubs?
tr8coupe
Postby tr8coupe » 10 Mar 2013 19:01
[:D]they are fantastic brakes as my Wife drives a 20v turbo every day and they will be able to stop your big v8 are you getting close to the 500 bhp ??
fiat is 98 ml tr7 95.2 ml [8D]
BMW Z1 ( sold)
TR8 coupe
Ginetta G27
TVR VIXEN (sold)
Postby Beans » 10 Mar 2013 19:09
Beans, you do have to be a bit careful with bells ... <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Thx for the warning, but the set up has on the car for 6 years now without problems.
And the bells have a centring ridge for the discs and slightly oversized holes.
As for your disc failure, that might well be caused by the fact that they were drilled, probably the reason why they chucked them away after a few events.
Especially as they had been used in (should I say fierce?) competition.
That's why I use grooved instead of drilled discs.
Benzo
Postby Benzo » 10 Mar 2013 19:45
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by tr8coupe</i>
[:D]they are fantastic brakes as my Wife drives a 20v turbo every day and they will be able to stop your big v8 are you getting close to the 500 bhp ??<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
I never actually found them that good on the Coupe, but it was 350hp as well on standard pads [:0] Some DS2500's would probably have changed that!
The BMW engine runs 300hp standard, hoping to achieve around 350 from it and get the car down to around 920kgs.
At the moment i'm looking at a set of MGTF Trophy AP's they are designed to work with a 305mm vented disc.. they could be a good starting point calliper wise. I think i will just pick up a set from eBay and do some testing, worst case scenario i have to sell them on again.
Benzo
Postby Benzo » 10 Mar 2013 19:48
Also,
Leon Cupra R Brembo's are Radial mount but not sure what i will get under a 15" wheel!
Postby dursleyman » 10 Mar 2013 22:48
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">As for your disc failure, that might well be caused by the fact that they were drilled, probably the reason why they chucked them away after a few events.
Yes Beans we thought that too and ran solid discs afterwards just to be sure and they were just as good.
1980 TR7 Sprint DHC
Benzo
Postby Benzo » 11 Mar 2013 11:24
For anyone interested in an AP brake setup, Alastair Flack at Hamilton classics is looking on a set of bells and Caliper carriers to mount radial fit 6r4 style open back calipers on a 295/304mm disc to work under 15" wheels.
Postby Beans » 11 Mar 2013 16:40
HiSpec do a complete kit that bolts straight on a TR7/8
http://www.hispecbrake.co.uk/TR7300M.html
And the "smaller" of the two option fits inside 15" wheels ...
Don't know about the 6 pot callipers though ...
Users browsing this forum: No registered users and 228 guests
