Steve, air con equipped TR8s had twin electric fans mounted in a cowl behind the radiator. These were two speed fans, primary low speed switching coming from temperature switch fitted into the radiator, & secondary high speed from a switch in the inlet manifold. The fans served to cool both the normal engine coolant & the air con system when in use.
There is a complicated system of relays associated with this set up, to recreate the loom would take quite some work!
To the best of my knowledge, the air con TR7s had a similar set up, but the fans & cowling are different from the TR8 units. I guess it would be possible to wire the fans just to run at a single speed off a thermostatic switch, or maybe one fan then both together if things get really hot! Of course you would need to find the fans & cowl, and associated brackets, which are rare over here as we never had A/C TR7s!
