Mystery Screw
whitenviro
Mystery Screw
Postby whitenviro » 01 Aug 2012 15:02
While cleaning out the car I found this screw under the edge of the drivers side (left) floor mat. Its about 2&1/2 inches long and probably came from under the dash. Anyone recognize it or have an idea where it belongs?
[/img]
HDRider
Postby HDRider » 01 Aug 2012 15:04
It is from the steering column cover.
Edward Hamer
Petaluma CA
Postby stevie_a » 01 Aug 2012 15:12
<font color="teal"><b>X2 on the cover.
there are two of them in there.</b></font id="teal">
Ianftr8
Postby Ianftr8 » 01 Aug 2012 16:54
dont overtighten the screw when you put it back as the bezels are known to break.
Ian
Ian Freeman
1979 TR8 DHC
Triumph Courier
Triumph owner for 31 years
Postby FI Spyder » 01 Aug 2012 18:30
I was missing that screw (cover held on by one) so I ordered it from Octagon on next parts order but got one half that length. I found the missing screw under the molded carpet when I took it out. No idea how it got there, for those who know a molded carpet it's not easy to get from under steering column past raised edges.
Postby PeterTR7V8 » 01 Aug 2012 21:57
I was expecting some other topic of conversation. [}:)]
Postby jclay (RIP 2018) » 03 Aug 2012 12:44
Easy way to install this screw:
Cut two 2" long piece of fuel line hose. Turn bottom cover up side down. Put the screws in the holes and let them drop all the way down. Push the pieces of fuel line hose into the openings.
The fuel line hose will hold the screws up while you align the screws into the connector and it will also automatically align the Philips head screwdriver to the screw. Once install, just pull the hoses out of the bottom of the cover.
Ianftr8
Postby Ianftr8 » 03 Aug 2012 16:39
That's a neat trick Clay - those screws are a real bugger to line up!
Best regards
Ian
Ian Freeman
1979 TR8 DHC
Triumph Courier
Postby Cobber » 03 Aug 2012 23:07
<font size="2"><font face="Comic Sans MS">Peter this is the TR-7 forum not the Sheep Fanciers forum [:D]
</font id="Comic Sans MS"></font id="size2">
'98 MG-F, 69'Ford F250.
Postby PeterTR7V8 » 04 Aug 2012 06:01
How roo'd!
FWIW I've managed to patch up a split in the plastic that holds the brass thread thing in the top shroud with a very small hose clamp. It's been doing the job for about 2 years so it is a permanent fix now. Don't even bother with glue.
Now, I'm off to do some olympic gloating.
Postby stevie_a » 04 Aug 2012 07:48
<b>Now, I'm off to do some olympic gloating</b>.<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
<font color="teal"><b>Is it that time already, I thought the woman's beach volleyball was on later in the day..[:D]</b></font id="teal">
Ianftr8
Postby Ianftr8 » 04 Aug 2012 18:52
"Now, I'm off to do some olympic gloating."
Oh g<u>l</u>oating! I thought we were back to the sheep and goat fanciers again!!!
Ian
Ian Freeman
1979 TR8 DHC
Triumph Courier
Users browsing this forum: Google [Bot] and 282 guests
