A sad and heavy heart - must sell!
macmattom
Postby macmattom » 19 Nov 2011 21:28
<font face="Comic Sans MS"><font size="2"><font color="blue">After nearly 5 years, and within sight of the finishing post, it is with a sad and heavy heart that I have to accept the inevitable and must sell my beloved 1976 FHC. I am so close it hurts, but being in the Armed Forces has once again conspired against me and a new posting has scuppered my chances of finishing my project.
I now have a decision to take, and decide whether to sell the whole thing as a project, or to break it up into "lots" and sell it as an engine, body shell, etc. As a project, I reckon a few short weeks will see the car back on the road. I just have to rebuild the engine and drop it in, fit the seats and the doors, then stand back and admire my hard work. Alas, that’s not an option.
The rolling shell is immaculate. The body has a “Viper" (I think) body kit and has had a full bare metal respray in Toyota MR2 red. The underside has been Tetrasealed, even under the tank. The entire body shell (except the rear deck), doors, bonnet and boot were all rust free BEFORE the respray. A new rust free rear deck was welded in before the respray so this body shell is now virtually totally rust free – a very rare beast indeed. The Webasto sunroof is effectively brand new, having been professionally re-covered but still needs to be fitted. The radiator does not leak and has a Kenlowe electric fan with electronic sensor unit to replace the standard “bulbâ€￾ sensor. All locks were stripped back to the tumblers and reset so that one key now fits all locks and the ignition. The door catch plates on the door and the B Frame have been chrome plated. I hand-made a new set of B panels and got them professionally re-covered, and fitted a new glass-fibre parcel shelf. All the light units (back and front) were completely stripped back to bare metal and resprayed with chrome paint before being reassembled with new gaskets. The front light lift mechanism was totally stripped, cleaned, refurbed and reassembled. The lights all work properly, with front and rear fog lights wired in separately. The fuel tank has 5 gallons of fuel in it and not leaked a drop and the gauge reflects this. There is an electric fan with electric sensor, chrome-plated wiper motor, new wiper wheels and all gaskets and grommets have been replaced.
Both sets of running gear have been completely stripped and overhauled and have a set of steel wheels with new tyres (still got the nobbles on!). The front hubs have new bearings, dust shields, shocks, track-rod ends and gaiters. The strut-tops have the roller bearings to reduce effort and anti-dive blocks. The rear axle has new shocks and a new handbrake cable, and all tie-rods and anti-roll bars have been Hammerited. To finish it off there is a set of refurbished 4-pot callipers with brand-new discs, pistons and seals on the front and new shoes and cylinders on the back.
The interior trim in red check is IMMACULATE, with no tears, rips or splits. A new arm-rest cover and rear panel in black match the new black carpet (with sound-proof underlay). The dashboard was removed and completely cleaned before being refitted with red air vent meshes (they look great). The seat runners have been refurb’d and operate freely, and the fasten seat-belt switch works properly.
All electrics work perfectly except the “Passâ€￾ flash (the lights illuminate but don’t pop up – they do when used normally). All the electrical switches on the dash and the steering column stalk were stripped back to the contacts and cleaned before being reassembled. There are front and rear fogs and a halogen conversion on the main lights. The heated rear window, electric flasher units for indicators and hazards, horns and wipers all work perfectly. The wiper motor has been chrome plated and the mechanism has brand-new wiper wheels. The modern 4-speaker stereo system has an attachment for i-pods and USB sticks and sounds fantastic. The heater was stripped back to component parts, cleaned, repainted and had new foam fitted and it works perfectly on all speeds and settings. All the dashboard instruments work; rev-counter, voltmeter, fuel gauge, water temp gauge and even the clock keeps good time. The dashboard-lights rheostat and the fasten seat belt light work correctly. I can’t guarantee the speedo as the car hasn’t moved under its own steam for years.
Now the engine. The block has been rebored and has new pistons and bearings. It has been degreased and painted silver. I have resprayed all the covers and blanks in red to match the body, including the water pump cover, oil filter housing, transfer plate, oil pump, sump, fuel pump, dipstick, starter motor, engine mounts, alternator brackets and lifting eyes. I have also bought a spin-on oil filter and a brand-new 12-vane water pump. I was going to convert the engine to a Sprint engine. The 16V dizzy has been stripped and refurbished and I have an entire new ignition system, including coil, condenser, points, plugs, Magnecore leads and dizzy cap. I have the full set of double geared timing gears and a brand-new, never fitted timing chain kit. The 16V head which has been skimmed, had a new camshaft fitted, the valves re-seated and all the valve gaps professionally set-up. I even have the correct water jacket to allow the heater to remain connected (apparently these are very rare). The inlet manifold has also been completely overhauled. I paid for the SU Carbs to be professionally overhauled and have fitted brand-new K&N filters.
I have hundreds of photos (see my photobucket page) and loads of receipts to prove the pedigree. So my dilemma is do I sell everything as a single project or split rolling body, engine block and 16V conversion kit? I know I will get nowhere near what I’ve paid for everything, so my loss will be somebody’s gain, but I think the best way to recoup some money will be to sell off in “lotsâ€￾. I will look at what I’ve got and over the next few days offer them up for sale, so if you’re interested keep an eye out. If in the meantime somebody wants to make me an offer for anything, please send me a message and we can talk cold, hard cash!</font id="blue"></font id="size2"></font id="Comic Sans MS">
(4 and 1/2 years and counting - but who's counting!!)
Postby Beans » 20 Nov 2011 00:10
That's sad news indeed [B)]
Postby john 215 » 20 Nov 2011 08:35
Is there any chance of 'moth balling ' it ie. stick in someones lock up so you still have it to finish it when you can ? After all that work would be such a shame to break it up and sell it. [:(]
1976 Speke FHC Beauty
macmattom
Postby macmattom » 20 Nov 2011 11:58
<font face="Comic Sans MS"><font size="2"><font color="blue">Cheers John, but not really. I will be away for about 2 years, so on top of the 5 I've already spent that'll make 7. I wish I could ship it with me to give me something to do in the evenings. I'm probably going to lose a couple of thousand pounds as it is. Time to admit defeat, as much as it hurts. Ebay it is I'm afraid! [V][xx(][V]</font id="blue"></font id="size2"></font id="Comic Sans MS">
Postby FI Spyder » 20 Nov 2011 14:03
Not a good situation. Project cars get very little here although your's sounds like it's very near completion. I picked up Yellow TCT with 30,000 miles that was in primer stage ) although it needed total strip down which I'm doing now (for $100) after missing a coupe that had new paint, interior and mags for $600. It just needed a few interior pieces.
It had been sitting in paint shop for 9 years so would need a strip and clean to match the exterior.
Moving around is one of the disadvantages of armed forces but keep thinking of the early retirement and pension if you stick it out. All the time in the world for projects then.
Postby busheytrader » 20 Nov 2011 16:45
I've been watching your posts as they appeared and really admired the finish on your car.
As you're so close to the finishing post is there no-one you trust who could do it for you? (paid or unpaid) <font color="blue">"<i>I just have to rebuild the engine and drop it in, fit the seats and the doors, then stand back and admire my hard work. Alas, that’s not an option."</i></font id="blue">
Obviously I'm not in your shoes but if my company was posting me somewhere else in the world my question would be, "If my car was finished, would I able to take it with me or store it somewhere for my return?" If so I'd do all I could to finish it.
I already have a Mini Cooper in bits that I'm restoring and after that the 7V8 needs some serious refurbishing. Otherwise I'd be very interested in yours.........
Keep the car somehow or you may well regret it in later years. FHC's don't fetch much on the open market but would you be able to buy one of a similar standard in the future, probably not.
Good Luck,
Postby tr7inc » 27 Nov 2011 11:05
Hi Mac, its Steve im so so sorry to hear you have to sell youre pride i know how much time and effort you have spent on it, having seen it for myself, do keep in touch and once again very sorry mate.
steve
Postby dursleyman » 27 Nov 2011 14:14
Mac, It would be great if you could find a way to store/keep the car until you can get back into it. It would be a terrible shame if you have to abandon or sell now.
BUT if you do decide to move on please let the list know so someone here might give it all a good home.
1980 TR7 DHC
Postby Maxwell » 27 Nov 2011 15:45
<font size="3">I'd be interested in the car myself if it were this time next year. However, at the moment I've a Charitable drive to undertake, and no spare dosh!
www.team-phoenix.co.uk
Maxwell</font id="size3"> [}:)]
3.5 TR7 V8 Drop Head \ Oliver
0.7 Smart Roadster \ Oscar
macmattom
Postby macmattom » 28 Nov 2011 07:20
<font face="Comic Sans MS"><font size="2"><font color="blue">Guys/girls,
I am extremely sad to say that my head has ruled my heart, and I must sell. It's possible I could have finished the project, but with only 6 weeks before my new job starts overseas, I don't have the time to organise a lock-up (what with all my other commitments I need to arrange). Another consideration is that the car will be laid up for another 3 years until I return, and in that time things will obviously dry up, cease up or just plain stop working! I will hope someone else can benefit from my work and get the car MoT'd and enjoyed as it deserves to be.
So, if anybody is interested, please read my fuller description on the "For Sale>Parts>Complete rolling shell - except engine" - I'm open to sensible offers!
Thanks again for your continued help, support and encouragement, because without this site I would not have gotten as far as I did - absolutely brilliant.
macmattom
Postby macmattom » 28 Nov 2011 20:43
<font face="Comic Sans MS"><font size="2"><font color="blue">Well, I sold the engine over the weekend. Gutted doesn't even come close. I didn't get anywhere near what it had cost, but was pleasantly surprised by what 2 LT77 gearboxes went for - that sweetened the bitter pill a bit!
I'll be putting the shell on eBay soon, but as already mentioned, if anybody wants to make an offer please look at the item in the For Sale>Parts>Complete rolling shell - except engine.
A great winter project to transplant a good engine into - go on, spoil yourself!
Users browsing this forum: jeffremj and 249 guests
