TR vs MG fall rally
trekcarbonboy
TR vs MG fall rally
Postby trekcarbonboy » 23 Oct 2011 00:48
Had a great time at the fall rally today. Only wedge to show up although 2 of the other guys have wedges also. Really fun roads for a LBC. We covered 58 miles and figure we had accumulated enough points to at least be in contention. Didn't win but at least the Triumph club took back the "Lucas Cup" from the MG club.
Had to cut it a little short though, bad noise started coming from the front. At first I thought it was the fan clutch but fortunately ended up just being the alternator bearings. Made it to the finish and just took off the belt for the ride home. Low 60's today so no problem keeping it cool. Only 40 min from home so no problem on battery power.
Anybody know if the 1980 air cond 95amp alt will work in a 75 with no air. I'll check the search after I'm done with this post.
Friend Jordan was my navigator. Next time remind me to find a navigator that DOES NOT weigh 240lbs![:D] Or I should just get a V8
GPS of our route.
This Turkey had a thing for the Spitfire. Even tried to get in the window!
Cars at the finish. Only 4 MG's showed up.
Hood up at the finish![B)] Easy fix. Didn't make it to the lineup though.
Craig '75 2.0 FHC
Postby jclay (RIP 2018) » 23 Oct 2011 05:28
The Saturn one fits just fine. Find the instruction on my public site.
Postby John Clancy » 23 Oct 2011 11:43
As long as you're sure it's not just the two halves of the alternator fan belt pulley guide rubbing together and making a godawful racket. If you have that type of pulley guide then it is a common fault as the washer between the two halves eventually wears out; but it is an easy fix.
trekcarbonboy
Postby trekcarbonboy » 23 Oct 2011 16:09
Thanks Jay. I was checking out your site last night. I always go there first![:)] I can't find an alternator with that 8215 part number but think I found the equivalent. Definately going for the big amps. I have a used replacement for the meantime. Have to make a trip to mom's parts shed.[:D] I'll throw that in on Tuesday.
John.. No doubt that the bearings are toast. But good info.
Craig '75 2.0 FHC
Users browsing this forum: No registered users and 244 guests
