New TR7
jimmyanderson123
New TR7
Postby jimmyanderson123 » 18 Apr 2011 06:20
HI there, I have just bought my 2nd ever TR7, its a 2.0litre in green with a full length sunroof. if anyone has any advice as to issues that i need to look out for or if anyone wants to come round and help they are more than welcome. the car is a runner with mot this time. thank you for your time
Laird Scooby
Postby Laird Scooby » 18 Apr 2011 06:24
Morning Jimmy and welcome!! You're beating me by 2 TR7s, i'm currently looking and joined here for advice and to maybe find a suitable car.
What i have found is a very friendly, knowledgeable bunch so you're certainly in the right place for Wedge shaped things!!
Dave
rocky_679
Postby rocky_679 » 18 Apr 2011 09:32
hi 2 u both this site has very nice people very helpfull full of knowledge an allways spot on with their advice [:D] gd luck to u both
stephen j dark
Bobbieslandy
Postby Bobbieslandy » 18 Apr 2011 10:45
Hi! my only advice is to drive it, enjoy the weather and if anything's amiss then just ask.
Where are you Based Jimmy?
Rob.
Postby FI Spyder » 18 Apr 2011 15:14
Is this a daily driver or second car? If every things working well enjoy. I would systematically take apart each electrical connection, clean with some contact cleaner rubbing it with a piece of cloth or brush, blowing out/off (with compressed air if you have a well stocked garage) and applying a thin film of dielectric grease. This can be done as time allows and can be done with just a little mechanical experience. Perusing these posts will tell you that many problems are dirty/corroded electrical connections of an thirty year old car without the sealed connections of a modern car. It can be as good an excuse to get you out of the house as polishing the car and while it won't make it any prettier it will make it more reliable.
Post a picture when you get a chance. There are "sticky's" that tell you how.
prlee
Postby prlee » 18 Apr 2011 19:42
I got my TR7 with an MOT, jusgt check all the systems over, brakes and electics etc. You wont know its reliability until you run it, some things will fail some wont.
When I ran mine the alternator failed, water pump failed, sticking needle valves in the float chambers, advannce weight sticking in the distributor.
Check out hoses, coolant and fuel, anyhing perishable. The car needed some relays repalced and a brake slave cylinder replaced.
Pete
81 Carmelian Red DHC
79 Pageant Blue Spitfire
Image Image Image
Postby Beans » 18 Apr 2011 20:29
Agree with Rob, enjoy driving it as much as possible [:)]
And welcome here.
jimmyanderson123
Postby jimmyanderson123 » 19 Apr 2011 05:04
hi there, thanks for all the advice! I am based in Bristol UK, drove her home yesterday 250miles, ran sweet as a nut! maybe it could do with a tune and wheel balance and tracking which i shall hopefully have today. everything worked like it should which is good until I hit a bump and then the fuel gauge went off!! no biggie but the the fuel warning light still works so my guess is gauge has a loose connection??? and not the sender right??
Postby john 215 » 19 Apr 2011 05:55
[:D] WELCOME TO THE BEST TR7 / 8 FORUM IN THE WORLD EVER [8D]
FHC getting a rare car nowadays [:(] shame because IMHO they drive better than the DHC. If you get a chance pictures are always good.
As far as fuel gauge, poss conectors on tank but worth checking the connections on the back of the instrument cluster or the printed circuit itself.
jimmyanderson123
Postby jimmyanderson123 » 19 Apr 2011 13:01
how do i upload photos
Postby FI Spyder » 19 Apr 2011 14:25
Gauge problem is surely wiring connections at gas tank or more distant possibility under dash. See my previous post about wiring connections above.[8D]
There is a "sticky" at the top of this section about posting pictures. Can't wait to see them. Sounds like you have a good "base" car.
jimmyanderson123
Postby jimmyanderson123 » 19 Apr 2011 17:24
hope this works not sure yet how to make them smaller but hey!Image
prlee
Postby prlee » 19 Apr 2011 18:10
Hi Jimmy, I in Wotton-under-Edge, so not too far from Bristol.
Car looks pretty sound just some work to the sunroof?
Pete
Image Image Image
Postby FI Spyder » 19 Apr 2011 19:21
Looks pretty nice to me. Got to get that roof fixed so it doesn't leak water inside.
Spectatohead
Postby Spectatohead » 19 Apr 2011 19:58
Very nice. What year is it? I notice that it has a late style bonnet. Later coupes are really hard to find, especially with the sliding roof.
Jim Clark
'80 TR8
'97 Maxima 5spd
Users browsing this forum: No registered users and 231 guests
