running lumpy
rocky_679
running lumpy
Postby rocky_679 » 12 Apr 2011 14:05
ok fitted 4 branch manifold with big bore silencer no centre box fitted gaskets to manifold an sealed all the joints when starting the engine i get a backfire the she idles at 1000 revs if i drop the revs she idles iratically an wants to cut out ive been told i must uprate the needles to the carbs an fit KnN filters in conjunction with the 4 branch manifold to run smooth has any1 else experienced uneven tickover when puttin 4 branch manifold n bigbore exhaust [B)]
stephen j dark
Postby Beans » 12 Apr 2011 21:13
You changed the breathing of the engine,
so you must change the carb's needles.
rocky_679
Postby rocky_679 » 12 Apr 2011 22:47
have ordered uprated needles an knn filters an givin the engine a service [:D] thanks beans
stephen j dark
Postby Hasbeen » 13 Apr 2011 01:57
Stephen, I did not have a problem with idle, after doing the exhaust, & inlet. It was at higher revs I needed the richer needle. The thing would not rev past about 3500 RPM without those needles.
Was your backfire through the carbs, or the exhaust? I have found backfire through the carb is usually caused by closed up inlet valve clearances, or indeed a riding valve.
Backfire through the exhaust has usually been down to sucking air in somewhere it shouldn't, or one of those damn fool air pumps pumping it in.
Bad idle has usually been down to unbalanced carbs. One doing all the work, & the other admitting very little, or virtually no air at all at idle, or the float level being so far out on one carb, that it provides little fuel, so its cylinders are running very lean, below 1250 or more RPM.
Unless it's a spark plug problem, or a coil or a lead or------, well you know the rest.
Of course you still must uprate those needles.
rocky_679
Postby rocky_679 » 13 Apr 2011 12:41
the backfire was thru exhaust put some new fuel in it an cured backfire tho still running up n down at idle doing a service on her 2morro see if that cures it then friday new needles n filters i was told that the small pipes leading to the air filters i could block off as im running k n ns is it better with or without pipes ???
stephen j dark
Postby Beans » 13 Apr 2011 17:38
Some pictures how I solved that in my weblog (labels <i><u>SU</u></i> and <i><u>8V engine</u></i>)
Users browsing this forum: No registered users and 230 guests
