Correct thermostat setting
macmattom
Postby macmattom » 26 Jan 2011 23:35
<font face="Comic Sans MS"><font size="2"><font color="blue">Can anybody suggest what is the best thermostat setting to fit to a normal 8-valve engine for general use (not racing)?
Thanks
(nearly 4 years and counting - but who's counting!!)
Postby DNK » 27 Jan 2011 00:04
You mean Temp?
"No More Cars For You"
71 TR6- Perpetual remodel
macmattom
Postby macmattom » 27 Jan 2011 00:11
<font face="Comic Sans MS"><font size="2"><font color="blue">Don,
Yes - I've seen thermostats set for 72, 82 and 88 degrees. What should I be considring when I buy a new thermostat.
Cheers.</font id="blue"></font id="size2"></font id="Comic Sans MS">
Postby Workshop Help » 27 Jan 2011 03:12
It's kinda like the story of Goldilocks & the Three Bears. That one is too hot. That one is too cold. But that one in the middle is just right.
Postby FI Spyder » 27 Jan 2011 04:50
More important than temperature rating is making sure you have the right type as the temp rating is when it opens to allow water to run through the radiator. At operating temperature it will run hotter than any of those settings. More important is that it has the Triumph foot as seen on the thermostat on the right as that closes the by pass and allows all the water to run through the radiator. With out the foot only a portion of the water will run through the radiator drastically reducing the effectiveness of your cooling system.
One at left is from VB and the one at right is from Robsport (by special request.)
The 15 lb. cap runs the cooling system at 1 atmosphere above normal raising the boiling point of the water above 100C (212F) much like a pressure cooker. The coolant also raises the boiling point (and lowers the freezing point).
In Manitoba we used to change out the thermostat for one with a higher rating in winter time so the engine would warm up quicker and hence would heat the interior quicker. We would also block off the radiator with a piece of cardboard with a flap or circle cut out. Alternately you could buy a vinyl radiator covering that had flaps you could open.
That would be in 20 to 40 below zero. (40 below is the same in F and C). Nothing like that on the west coast.[8D]
Postby gaz » 27 Jan 2011 08:52
you know i'll understand why she never got busted for trespassing...............
Users browsing this forum: No registered users and 243 guests
