uprated springs
rocky_679
uprated springs
Postby rocky_679 » 25 Jan 2011 18:44
i want to fit uprated springs can i fit standard shocks and inserts if all bought new as a package rimmers sells a package as decribed or do i have to fit uprated inserts n uprated shocks [?]
stephen j dark
Postby Shauniedawn » 25 Jan 2011 19:10
If you are going to put stiffer springs on, then i would say uprated shocks would best match them. Standard ones are likely to overheat and not do their job. Matched sets would be the best advice.
Shaun
rocky_679
Postby rocky_679 » 25 Jan 2011 19:30
thanks shaun mate.... got the electrics done today an new steering wheel fitted [:D]
stephen j dark
prlee
Postby prlee » 26 Jan 2011 19:22
I'm about to go back to the orignal springs, I find the ride a little too firm.
I wasn't really happy with the front, ride was ok but didn't lower as expected. It will have had polybush through out and new shocks, the orignal front had lost all resistance.
Pete
81 Red DHC
79 Blue Spitfire
Image ImageImage
kstrutt1
Postby kstrutt1 » 26 Jan 2011 20:13
Go for uprated or adjustable dampers, I fitted gaz a djustables and 200lb 2" lower springs, I found the rear springs too short, it kept crashing through to the bumpstops which threw it all over the road, I replaced them with ones a coil and a half longer which only lowered it a inch or less but work much better.
prlee
Postby prlee » 26 Jan 2011 20:33
I currently have the uprated lowered springs, Avo shocks rear which I dont recomend - noisy and bottom out too early, will be fitting KYB, fronts have uprated springs which are dont lower enough with KYB shocks.
Ideal would be progressive rate springs but these dont seem available these days. I have now decided the standard height doesn't look that bad anyway.
Pete
81 Red DHC
79 Blue Spitfire
Image ImageImage
Postby Beans » 26 Jan 2011 20:46
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by prlee</i>
... Avo shocks rear which I dont recomend - noisy and bottom out too early ... <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
[url="http://tr7beans.blogspot.com/2007/07/rear-damper-problems.html"]<u><b><font size="2"><font color="red"> Found that out</font id="red"></font id="size2"></b></u>[/url] a few years ago ...
Koni for me any time [:D]
prlee
Postby prlee » 26 Jan 2011 20:58
I know Beans, we have been here before and I will junk the AVO as soon as I can. I trust KYB are short enough, didn't think Koni were still available.
Pete
81 Red DHC
79 Blue Spitfire
Image ImageImage
Postby FI Spyder » 27 Jan 2011 05:43
Front springs are listed on Koni Canada/USA website but no prices on rears. Triumph not listed on other country websites.
Maybe Beans can find a stash of NOS shocks in the motherland.[8D]
Users browsing this forum: No registered users and 199 guests
