Relay investigation????
zekow1
Postby zekow1 » 02 Dec 2010 23:50
Hi Guys
Today I have an interesting one.
After checking all the relays in the car I found that in the glove compartment there were three types :
The Metal one which i did not take a picture of
And these two . As you will notice the one on the left [ The round one for those who live in countries where they don't know the difference between driving right and wrong ( left)][:D]
The power switches from 87A to 87
While the other one Is Off and then switches Both 87 at the same time
Which one goes where???
Nope!! it's still not running ,Maybe next week???
Gubi
Postby Gubi » 03 Dec 2010 00:26
What year is the car?
Unless my memory is going, my '79 has a dual-87 output relay on the starter. One output goes to the starter and the other goes to the coil (to provide full voltage while cranking). But I don't have the wiring diagram in front of me to verify this so best to double-check.
Tom
'79 TR7
'87 Alfa 75
'91 Alfa Spider
zekow1
Postby zekow1 » 03 Dec 2010 00:39
Sorry about that
1981 TR7 EFI
Gubi
Postby Gubi » 03 Dec 2010 06:15
Well, from what I can see on the wiring diagram the starter relay wiring is quite different on an '81. Looks like just a standard 87-87a but I can't really tell for sure. So I don't think my comment above is applicable to your car, sorry.
Tom
'79 TR7
'87 Alfa 75
'91 Alfa Spider
zekow1
Postby zekow1 » 03 Dec 2010 23:14
I figured it out
The one on the left theround one is one of two relays for the front light motors.
The other is a starter relay.
Philip
Postby Philip » 08 Dec 2010 09:41
Round or square is largely immaterial unless you are fixated on oringinality. The original Prince Of Darkness (Lucas) relays are round and quite tall. Modern replacement relays (such as Bosch) are square and much smaller in height. I replaced my Lucas with Bosch some time ago. Now if I could just find a replacement for the Pektron !
Still standing !
Postby FI Spyder » 08 Dec 2010 15:13
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by zekow1</i>
I figured it out
British Parts Northwest has the square one which is listed for $12.95. It's a starter relay and other things. I bought one as a backup cause it's cheaper than a Lucas (and probably better).
http://www.bpnorthwest.com/.sc/ms/dd/TR7-TR8--Engine%20Electrical/10237/Relay%20Multiple%20See%20Description
Users browsing this forum: No registered users and 379 guests
