Floor
Postby FI Spyder » 11 Apr 2014 14:29
Of the 8 bolts holding down the two seats 7 looked brand new like they just came out of the factory and one was rusted solid. The anomaly I could only assume was from something like a spilt coke on the bolt causing it to rust prematurely. It took me a week to get it out working it in and out with soaking with penetrating oil. There is no way I was going to force it, brake it off and have to drill into the bolt to get it out (I hate that). I had plenty of time as I was doing a fall/winter of removing interior and spruce up so time wasn't an issue. It eventually came out and I replaced it with an Allen head bolt which is easier to remove than the Torx heads. I've used anti seize as they extend down below the floor.
Postby DNK » 11 Apr 2014 14:54
OK what size Torx so I can get a socket adapter?
Stick a Wedge In It
sonscar
Postby sonscar » 11 Apr 2014 15:19
On my extremely rusty car 7 of the bolts undid easily but the 8th had been replaced at some time by an ordinary set bolt and nut.As the head will not fit into the seat runner and the nut is no longer captive it was loose and the seat rocked about which probably contributed to the floor cracks on the tunnel.As the seatbelts mount to the seat the years of MOT passes were obviously lenient.Steve..
trekcarbonboy
Postby trekcarbonboy » 11 Apr 2014 15:28
On my car 1 seat had 4 equal length bolts. The other seat had 3 different lengths. Just whatever bolts where in the bin at the time it was bulit I suppose.
Craig '75 2.0 FHC
Postby Beans » 11 Apr 2014 15:32
Outside bolts screw into thick steel plates located inside the box sections.
These plates can move a bit, that's why it looks to be badly aligned in the picture.
The inside bolts screw into nuts welded to strengthening plates on the underside of the floor.
The spot welds for these plates are also visible in the picture.
Postby DNK » 13 Apr 2014 21:20
Put it in the air . The passenger rear was hard to see with the silencer over it.
Bet it makes it a little harder to remove with the heat on it.
The drivers rear, a piece of cake, to spray
The fronts...they like to hide them buggers
Hope the bolts on the channels are OK
They are shinny so hope they come out OK> Can't get any penetrating spray in there.!
Stick a Wedge In It
Postby busheytrader » 15 Apr 2014 20:10
On mine the Torx bolts are all the same length.
There was a thread sometime back stressing that all the original bolts are high tensile strength and shouldn't be substituted with a lesser item. I know which ones I'd choose to have holding my seat and seatbelts in place in the event of a crash.
Postby DNK » 15 Apr 2014 20:42
T30's
Went to ACE and picked up a 1/4 drive socket for it.
The ones on the inside that you can actually spray came out easier.
Just now pulled the seat
Stick a Wedge In It
Postby DNK » 15 Apr 2014 20:56
Bolt question
Sorry it's so small. Screwed it up
What's that bolt for
Stick a Wedge In It
Postby DNK » 16 Apr 2014 11:23
Has anyone measured the seat bolts for size.
Just measured mine.
A strange size.
8mm is to small and 10mm is way to large
same with 5/16 and 3/8's
Is there such a bolt as 9mm??
Stick a Wedge In It
Postby Cobber » 16 Apr 2014 12:13
Yes there is, the French use odd sizes like 7 & 9mm. Why? Who knows, it would seem that they just like to be different than everybody else.
Now, having said that, it's highly unlikely the they would be found on a Triumph, unless someone working on the car over the years decided to resize them.
However it is likely that they have a differnt thread count than those you tried to screw in.
'98 MG-F, 69'Ford F250.
Postby DNK » 16 Apr 2014 12:20
I pulled them out and stuck them in a thread gauge.
That's how I determined my findings.
Have not done a thread size yet as my garage was a little chilly for how I was dressed this morning
Stick a Wedge In It
darrellw
Postby darrellw » 16 Apr 2014 13:07
Don, the bolts are a self-locking type, if you roll them in your fingers you probably can feel that they are slightly triangular.
Darrell Walker
66 TR4A IRS-SC CTC67956L
81 TR8 SATPZ458XBA406206
Vancouver, WA, USA
Postby DNK » 16 Apr 2014 14:43
So the 8 X 1.25 is probably close then
Thanks Darrell
Stick a Wedge In It
Postby DNK » 16 Apr 2014 14:50
Ignore the bolt size
Stick a Wedge In It
Users browsing this forum: No registered users and 267 guests
