Wedge repair shop in St Louis area???
stever_sl
Postby stever_sl » 29 Jul 2011 18:41
I apologize for repeating this question, but the last time it produced John Mangles' name, and he has no interest in working on my car, so here goes again. I have a TR8 that runs VERY rough when it's hot, especially when the engine is under a load (climbing a hill with the AC on is almost impossible.) I've checked everything I'm able to do with my minimal mechanical skills (plugs, wires, distributor cap/rotor, carb mixture) and it's made no improvement at all. It's been to a local import car shop again with no improvement. I can't keep driving it the way it is and I can't seem to find anyone who knows much about Wedges. I'd really appreciate any leads!
- Steve Richardson
St Louis MO
76 TR7 (original owner)
80 TR8
Postby DNK » 29 Jul 2011 20:15
Look for an independent Rover mechanic.
Check Cars.com and car talk for a person in your area
"No More Cars For You"
71 TR6- Perpetual remodel
Postby tr8 » 29 Jul 2011 20:40
I would post the question on the TR7/8 mailing list. There are a few wedge owners in St Louis on that list.
Postby silverseven » 30 Jul 2011 02:35
and if all else fails ...did you ever think about visiting a speed shop that works on old GM'S ???
Image ImageImage
stever_sl
Postby stever_sl » 30 Jul 2011 13:51
A shop that works on old GMs? I'm not sure I see the connection there - but at this point I'm up for anything!
Vegas_M
Postby Vegas_M » 30 Jul 2011 21:15
FYI - The TR8 engine was originally from a 61-63 buick/olds 215ci. Rover bought it from them when they switched to a cast iron 300ci block.
Also, does your TR8 have the stock fuel injection, twin SU's or ZS carbs or a 4 barrel? If stock fuel injection, you might need new injectors and or seals. If twin carbs, check the mounts for leaks. If a 4 barrel carb, any speed shop should be able to help you out.
A quick search for British car repair in in St. Louis turned up:
All British Car Repair
2618 Woodson Rd, Saint Louis, MO 63114-4816
314.426.1600
British Cars of America
2338 N. Lindbergh Blvd.
St. Louis, MO 63114
314.428.9335
M.
Martin
Postby silverseven » 31 Jul 2011 02:07
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Vegas_M</i>
exactly ....any old school GM v8 guy should be able to work/tune your engine (once he gets over the fear of the british bodywork)
It could also be part of the reason people like to mod out their TR8's with simple 4bbl carbs, it's what they are comfortable with and work good!
Image ImageImage
Postby tr8 » 31 Jul 2011 03:46
Sounds like it might be the diaphragms in the carbs. If they are cracked or brittle and you loose vacuum you loose a lot of power.
stever_sl
Postby stever_sl » 31 Jul 2011 12:43
I should have remembered about the GM origins of this engine - getting old and forgetful! I took the tops off the carbs and checked - both diaphragms are perfect. I'm starting to suspect either the coil or the guts of the Pertronix in the distributor. A coil swap is easy enough but I'm not sure how to begin with the Pertronix, other than replacing the whole thing. I'll start calling the shops that have been mentioned here but based on past experience one of them isn't interested in my car(s) and the other is one of those dirty and disorganized shops that you hesitate to trust; still, I have to get some help on this. Dave - a carb swap might be just the thing to rule them in or out as the problem. I'm in unfashionable north St Louis County (Spanish Lake), where are you?
- SteveR
Postby Odd » 02 Aug 2011 10:13
Hi Dave! More parts to make that travel planning to? [:D]
/Odd
stever_sl
Postby stever_sl » 10 Aug 2011 00:30
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Dave Massey</i>
Steve, there is a quick way to check to see if it is your carbs. We can swap mine onto your car. My car ran great regardless of temperature and since it is off the road I won't need them for a while.
Dave Massey
SLTOA
Dave - I replied to your message as soon as I read it, but my reply seems to have vanished without a trace. Which is odd, since the exact same thing happened on the Wedgeparts forum this week. I didn't want you to think I was ignoring you, or didn't appreciate the offer. Unfortunately I broke my foot last Friday and it's going to be at least a month before I'm able to get back to work on the car. Where are you located? I'm in Spanish Lake, north St Louis County.
- Steve Richardson
Users browsing this forum: No registered users and 230 guests
