Dipstick Tube length
Postby Maxwell » 21 Apr 2009 18:51
Hi Thomas
The dip-stick is 570mm long.
The rubber sleeve from the engine block is - as
near as I can measure - 390mm long
The High Oil mark is Circa 30mm from the end....
Hope this helps.
Maxwell [;)]
tr7sprint1
Postby tr7sprint1 » 21 Apr 2009 23:53
i measured a dipstick assy i have off the engine, the tube is 16 inches or 406.4mm long.
Postby Hasbeen » 22 Apr 2009 03:28
Thomas, the official Leyland manual states the capacity of the sump
is 4 litres, [7 pints]. The capacity of the sump, & the old style
canister oil filter is 4.5 litres.
I suggest you drain the oil, tip in 4 litres, then adjust the length
of your replacement tube, so the dip stick reads full. Then there is
no guess work as to if you even have the right dip stick.
Postby PeterTR7V8 » 22 Apr 2009 03:55
My wife thinks her dipstick is 5'10".
Wot a liberty!
Postby Hasbeen » 22 Apr 2009 06:33
Perceptive, that wife of yours, isn't she Peter?
Postby FI Spyder » 22 Apr 2009 20:05
Can't seem to get a consensus. My TCT dipstick tube is 15 5/8" or 397mm long. Seems Hasbeens advice is most appropriate here.
Peter, has your wife been talking to my wife?[:D]
