float stuck
GRANTDCLARK
float stuck
Postby GRANTDCLARK » 16 May 2008 00:29
ANY SUGGESTIONS AS TO WHAT IS THE QUICK WAY TO GET A FLOAT IN THE CARB UNSTUCK. THE HOLE ( SIZE OF A SMALL PENCIL ) BESIDE THE INTAKE HAS FUEL COMING OUT OF IT WHEN THE CAR STARTS. THE FRONT CARB SEEMS TO WORK FINE.
THANKS FOR YOUR THOUGHTS.
Postby jclay (RIP 2018) » 16 May 2008 00:57
May not be a stuck float. Could be a leaky inlet valve or if you have an electric fuel pump, the fuel pressure is to high. No more than 3 lbs of pressure.
HUM? Looks like your caps lock key is stuck though!
Ferris
Postby Ferris » 16 May 2008 02:52
If it is truly just a sticking float, tapping on the carb's bowl with the plastic handle end of a screwdriver will shake it free.
It isn't likely, though, unless the car has been sitting for a long time. Trash on the needle, or a leaking float are common culprits for fuel running out the overflow tube.
Kevin Anderson
1980 TR7 DHC
1974.5 MGB GT
1990 Jaguar XJ40
Postby gaz » 17 May 2008 15:34
you could also maybee change the fuel lines (rubber) they tend to break down from the inside its maybee tiny peices of broken fuel line catching
It rides again
Postby Underdog » 17 May 2008 18:07
Check my post under Floats.
