milky oil on valve cover cap?
Mikey
Postby Mikey » 24 Mar 2008 18:43
I started up my 7 this past weekend after a 5 month winter hibernation. After a 10 minute warmup and a 10 minute drive at low speed-30-50kms; I shut her down and started inspecting things under the bonnet. To my dismay, when I removed the valve cover cap I discovered the oil on the underside of the cap was a milky whitish/grey color. I cleaned this off, put the cap back on and ran the engine another 10 mins. Same result but not as much as the first inspection. The car was stored inside but unheated. I had no such problems during the summer/fall of '07. I changed the oil and filter before winter storage and added one bottle of STP before starting this weekend. I do have a small coolant leak from the slot on the block under the water pump cover, but am planning a pump change in the next couple of weeks. Could this possibly be just moisture being boiled off from winter storage or something much more sinister?
Postby Beans » 24 Mar 2008 18:50
I'd say condensation in the engine, because of it's idleness.
Never let a car idle for so long after getting it out of winter storage. Start her up and immediatly drive of. Once on temperature, up the revs to get some decent heat in the engine. Should be OK then.
Just to be safe check your coolant for signs of oil.
Postby Rich in Vancouver » 24 Mar 2008 21:27
Wipe the goo out of the cover then take it for a good run and see if it reappears.
Also try removing the coolant filler cap and looking for signs of contamination, or bubbling (from compression) when the engine is running.
Postby john 215 » 24 Mar 2008 21:55
Hi Mikey,
Almost certain to be caused by condensation [:)] modern cars even run heater elements in breather hoses to stop this happening!
Cheers John.
Rblackadar
Postby Rblackadar » 24 Mar 2008 23:01
If it sat for 5 months during some cold times in it's hibernation, most likely condensation. no big deal.
Urchin
Postby Urchin » 25 Mar 2008 19:13
I agree with the wise posting above. You've got condensation. If after a run it does not disappear, consider changing the oil to get rid of the water content. All will then be well.
Jeff
Jeffrey Aronson
P.O. Box 90
Vinalhaven, ME 04863
USA
'80 TR-7 Spider
'66 Corvair Monza
dmachura
Postby dmachura » 27 Mar 2008 03:47
If the oil in your sump is not milky then it is condensation but I wanted to add another possible source of the oil froth, blow-by.
If your rings are gone or if the valves are not seating then the exhaust gases is the source of the froth.
A question I want to throw out there that relates to this topic, can anyone remove the oil filling cap while the engine is running without getting sprayed with oil?
Postby Beans » 27 Mar 2008 16:01
No, the timing chain runs underneath the oil filler cap.
And for lubricating it there is an oil thrower on the cranck shaft ...
Rayjones
Postby Rayjones » 27 Mar 2008 17:55
I can take the oil cap off my 2 litre 8v whilst it is running without getting sprayed with oil, at tickover anyway. And yes it does have oil in the engine!
Ray
1980 UK BRG 2L DHC
Postby Beans » 28 Mar 2008 23:30
And there should be a small oil hole in the tensioner, which should release quit a bit of oil.
Users browsing this forum: No registered users and 27 guests
