Fuel sender question.
Dave Dyer
Postby Dave Dyer » 21 Mar 2008 22:02
Hi All,
Has anybody at any stage of their TR7 rebuild ever tested the fuel sender unit ?
I have my tank out and I'm just about to refit it so checked the sender on ohms, but as I moved the float up I expected an increase in resistance, but it just jumped from 320 ohms to infinity! What should I expect to see ?
Any help would be gratefully received.
Dave
ngtf
Postby ngtf » 22 Mar 2008 17:31
Hi Dave
The sender should drop down to about 15ohms from memory when sender is in tank full position. It should also be reading something in-between those two figures at about middle of travel. It certainly should not go to infinity!!
Gary
Eeyore rides again !!
Dave Dyer
Postby Dave Dyer » 23 Mar 2008 20:22
Thanks for that Gary,
From what you say, it looks like its duff, I might as well change it while I have the access.
For something so important as to show the level of fuel in the tank, it seems such a weak design, in all the cars I've ever owned not one has had an accurate fuel display!!
Dave
flynns tr 7
Postby flynns tr 7 » 23 Mar 2008 20:32
did you have it connected to the right connector. if you look on the tank unit thier should be a T and W the t is the sender connector to the gauge.The W is for the waring light.
Dave Dyer
Postby Dave Dyer » 23 Mar 2008 22:16
Hi Flynn,
Good point, No I don't think I was measuring at the right connections, I'll look again tomorrow, I'll clean each one up to see which shows the T and W. I think I was measuring between them and from what you say I should be going between each one and earth.
Thanks,
Dave
Dave Dyer
Postby Dave Dyer » 25 Mar 2008 08:49
I rechecked between T and earth, test meter on ohms, as Gary had said it starts at a low resistance with the float up and gradually increases as the float is lowered.
Test completed- Pass!
Thanks again guys.
Dave
