The Affair
sunnie
The Affair
Postby sunnie » 05 Mar 2008 09:35
Hi All
Just wondered where ya might get a new indicator and light stick assembly. I know that there are 2nds available but was wondering if anyone knows/or aware of new parts, or am i dreamin!
Are there alternative versions around?
Gettin closer to drivin her!
The car is coming along new brake clutch system. Some rust to paint with POR15. I have the gloves ready for it.
There is a little rust but requires no real fixing should get away with just the brush. The only place where the rust has won is the rubber seal on the passengers side where the bonnet seals with the car just near the window. The rust won there which is a shame as that is the only real damage there is that i can see and i have been all over it.
I put an old battery on the car and the lights worked (Need to grease the gear sytem there) so that was a good start, but battery was not so good and the battery poles were smaller than the leads so i could not get a good connection but everything lite up.
Jclay's description of the sterring seal was spot on and it worked a treat, just have to paint the section where the hole is as the area has surface rust from the clutch and brake cylinders.
As always a million questions to ask when i read this group, keep up the great resource that this group is!
Over to the group
Sunnie
Postby TR Tony » 05 Mar 2008 10:46
Good to hear you are making progress, Sunnie.
Can't help you with suppliers over there in Aus, but some of the specialists in the UK still list these indicator/wiper switches. Try this one:
http://www.jamespaddock.co.uk/Stock.asp ... category=7
Not cheap & even worse for you guys with the £/A$ exchange, I guess it depends how much you want a new part.
sst
Postby sst » 05 Mar 2008 12:41
I got a new indicator switch last year from Victoria British..
http://www.victoriabritish.com
Postby Chris Turner » 05 Mar 2008 17:41
I got one recently from James Paddock as recommended by Tony.
www.triumphtr.co.uk
TR8 FHC
bottomtop
Postby bottomtop » 05 Mar 2008 21:56
Sunnie,
Can't help you out for QLD parts but here in VIC I use Pickards of Melbourne (Abbotsford) or Triumph Spares (Fairfield). Postage from VIC would be cheaper than O/S but the parts supply here is not as good.
sunnie
Postby sunnie » 07 Mar 2008 09:30
Ta for all that!
I will follow up on some of them
Ta Bottomtop I will check them out
Sunnie
Users browsing this forum: No registered users and 52 guests
