BONNET STAY HAVE I GOT THE RIGHT FIXING BOLTS?????
Postby tr7inc » 29 Feb 2008 18:07
Hi all just wondered by looking at the pics ive put on have i got the right bolt to fix the actual bonnet stay to the the turret?? it seems a little small thats all.
Anyway any help with this would be great.
Postby paul w » 29 Feb 2008 18:30
Steve,you do not need the nut.Push jack nut into hole in the turret,
put a washer on bolt and put it through hole in stay,then screw into
jack nut.As it tightens the jack nut collapses under pressure(a bit
like me!)and rivets itself to turret.Just check its the correct bolt by lightly screwing into the jack nut,if it dont thread,it aint the
right one!
p.s.you should have two bolts the same for bonnet fixing,one other
for turret.
Postby tr7inc » 29 Feb 2008 19:03
Many thanks Paul, i have the correct bolts for fixing to the bonnet, but i think the bolt that goes into the turret itself, is too small in lenght. any pics of what it should look like?? or is it similar to look at as this one only longer.
Many thanks again Paul
Postby tr7inc » 29 Feb 2008 19:25
I think the bolt im lookin for to place i the jack nut in the turret to hold the bonnet stay in place is no longer available to order ar Rimmers at least, any suggestions guys where i might be able to pick one up??
Postby saabfast » 29 Feb 2008 21:03
I assume that you think it is not long enough as the threaded section of the bolt might not reach the thread in the jacknut. You could try using a similar plain bolt to pull the jacknut in before fixing the strut with the shouldered bolt.
Postby tr7inc » 29 Feb 2008 21:42
Hi Saab many thanks yes i had indeed thought about trying that one myself
I may have a go tomorrow
Postby TR Tony » 29 Feb 2008 22:03
Like Pual says you don't need the nut but I think there should be a washer in there.
I should think that any of the specialist TR7 suppliers might have a used bolt. You could also try:
Triumphland
Bankwood Lane
Rossington
Doncaster
DN11 0PS
01302868450
These guys were recommended to me by one of the specialists (sorry can't remember which one now)who could not help me with what I wanted at the time. I have had a couple of small used parts from them & they have been fine. Might be worth a call if no one else can help?
Postby Rich in Vancouver » 29 Feb 2008 23:47
That makes things clear!
My car doesn't have the jack nut installed, just some bojack arrangement devised by a PO.
Here's a question...Mine is a very early car and has a slotted rail on the side of the inner wing to accept a bonnet prop rod. The bracket is still on the bonnet for the rod, but no rod.
I know it would be a step back to install the rod but if it should be there I just may do it...for shows if nothing else.
Has anyone seen a prop rod used on an early car?
Rich
Postby Odd » 01 Mar 2008 07:09
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by tr7inc</i>
Image<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote"> Steve,
from the picture above it looks like what you have is a kit for installing a boot lid stay! The yellow base
coated bracket in the middle of the picture is definitely the bracket intended to be fitted to the left side
rain gutter in the boot!
/Odd
Postby paul w » 01 Mar 2008 08:32
Odd,top marks,mate.You clearly see the 'bigger picture' when the rest
of us can't see the 'wood for the tree's'.
Steve,double check you got the correct stay(i dont know if its the
same length as boot stay,as i got those ram things)if ya got it from
Rimmers,it may well be wrong!!
Postby tr7inc » 01 Mar 2008 13:02
Hi Many thanks Guys i have doubled check and it is def the right stay for the from, all i did was clean the thing back up, althoigh why they took the jack nut etc out to begin with is a mystery to me.
Postby tr7inc » 01 Mar 2008 16:20
Many thanks Jclay
Postby tr7inc » 02 Mar 2008 12:11
Many thanks all, it now appears that i have a boot stay not a bonnet stay after all, is there much diference? i know they are both same lenght.
Postby Odd » 02 Mar 2008 15:14
Well, the two stays in my car are different. Not even similar in technical detail...
The bonnets stay is 477mm top to bottom edge (when upright and in lock).
The boots stay is 504mm top to bottom edge (when upright and in lock).
/Odd
PS
I'm interested in buying the entire kit from you - if you don't want it!
Since my dad's TR7V8 needs a complete boot stay kit to replace the stick (and gas struts) used currently...
