Handbreak swith
Handbreak swith
Postby UKPhilTR7 » 20 Feb 2008 06:51
<b><font color="red">I am lookig at changing the setting of my handbreak switch so that it comes on a little sooner when the handbreak is lifted up. Now I really have to pull it up hard (4 clicks) to get the lights to come on on the dash. I want them to come on after two (ish) clicks. Can this be done by simply moving the switch or do I have to do something more?</font id="red"></b>
Postby FI Spyder » 21 Feb 2008 00:06
If I remember right the switch is mounted on a bracket that can be formed to adjust the transfer point. I'm writing this from memory so I might be confusing it with the Spitfire setup.
TR7_FHC
Postby TR7_FHC » 21 Feb 2008 16:55
on my 78 the switch cant be moved, the "pip" on the end of my switch was quite worn, you should be able to bend the switch slightly or in my case I added a blob of solder which has worked for the last 2 years.
bottomtop
Postby bottomtop » 21 Feb 2008 23:29
Contacts on mine were dodgy. It a real physical origami job to get in there, I found.
Postby UKPhilTR7 » 22 Feb 2008 15:12
<font color="green"><b>I think I may have to go down the solder route as it does work, but needs a lot of pulling up to get the lights on. Will hopefully have a look at it this weekend and see what I can do, but it does not seem the easiest of jobs.</b></font id="green">
TR7_FHC
Postby TR7_FHC » 23 Feb 2008 05:52
On mine it was pretty easy to do, has to remove the centre armrest and gearstick surround but the switch was only held on with one screw. think I may have had to removed the handbrake assembly from the floor (left the cable attached) to rotate the unit and reach the screw as the seat was in the way.
