Resistance is futile
samco
Postby samco » 23 Jan 2008 16:38
I have just spent a whole day rebuilding my heater with new foam and seals for the matrix. Whilst bench testing it I found only the third speed worked. The fault was tracked back to the overheat device in the board with the first and second speed resistors. The overheat device (or thermal cut out) was badly corroded so I decided to get one from one of the other two heaters I had on the garage floor. Although one of them worked they were all badly corroded and I decided not to re fit any of them as I am trying to build in reliability. I have ascertained they are not available new so I am left with the choice of bypassing it completely (not my first choice) or hopefully someone has sourced one from another vehicle which can be adapted to fit. Any suggestions?
Check out my album
ngtf
Postby ngtf » 23 Jan 2008 17:16
Hi Samco, how about a purpose made heater fan switch.
Available from Neil Forman in Staplehurst, Kent. Yes, they do mail order as well. Ring on 01580 891309.
Kind regards
Gary
Eeyore rides again !!
Postby john 215 » 23 Jan 2008 17:19
Hi Samco,
The guy's at Robsport List them-
http://www.robsport.co.uk/buyparts.aspx
If you do a search on the above link they list them at £16.50 for a new one and £4.50 for second hand one,hope this helps.
Cheers John.
samco
Postby samco » 23 Jan 2008 19:16
Thanks John, it just goes to show I didn't look hard enough. I have just ordered one.
Check out my album
Postby john 215 » 23 Jan 2008 21:39
Hi Samco,
No worries mate,only to glad to help.
Cheers john.
Users browsing this forum: No registered users and 108 guests
