Brakes are gonna be my undoing!! Any options for?
mnypitTR8
Postby mnypitTR8 » 11 Jan 2008 01:30
OK I replaced the rear cylinders, brake rubber lines, rebuilt calipers and tried to rebuild the master. Unfortunately the master cylinder rebuild kit had poor quality seals and do not fit properly in the cylinder. So I ask, is there a master cylinder other than the over priced origional unit that I might be able to find locally?
And to top it off, I figured out why it has been running so poorly lately. The booster is shot. When I blocked off the vacuum line it smoothed right out and ran perfect. So any other options for that?
Maybe somebody has a set of used units they'd sell me cheap.
TIA
Frustrated as always when I work on this car
John Peacock
"like many other great ideas this too started with 2 guys in a bar"
80 TR7, Brooklands Green, Maybe on the road soon
98 Z28 over 500rwhp
mnypitTR8
Postby mnypitTR8 » 11 Jan 2008 13:47
That is not an option. We had sort of a falling out/misunderstanding about rust a few years ago. Nobody else has had any problems that I am aware of with him, but he did me wrong, so I wont smear his name, but I also wont use him either for anything.
John Peacock
98 Z28 over 500rwhp
mnypitTR8
Postby mnypitTR8 » 11 Jan 2008 13:50
Oh and I seem to have lost that one way valve somehow. Could that be the problem with the booster? Because I have 2 boosters here doing the same thing.
John Peacock
98 Z28 over 500rwhp
Urchin
Postby Urchin » 11 Jan 2008 15:02
Could be the problem. If you don't want to talk further to Woody, you might want to try Erick Van Sickle, Leyland English Auto Repair, in Keenebunkport, ME [207-967-2504]. He knows TR-7's quite well and has a lot of used parts in stock. He doesn't do junk either.
Jeff
Jeffrey Aronson
P.O. Box 90
Vinalhaven, ME 04863
USA
'80 TR-7 Spider
'66 Corvair Monza
Urchin
Postby Urchin » 11 Jan 2008 15:03
Just another thought. You might not have lousy seals, but you might have a pitted master cylinder body that is leaking out pressure. Not every cylinder can be rebuilt successfully.
Jeff
Jeffrey Aronson
P.O. Box 90
USA
'80 TR-7 Spider
'66 Corvair Monza
mnypitTR8
Postby mnypitTR8 » 11 Jan 2008 15:54
NO, the rear seal was so big I couldnt get it in the master cylinder. Not only that, the whole kit was only 4 seals, 3 of the front ones and 1 of the rear. No matter where I put that one seal, it would not fit in the master cylinder. Maybe the kit was shorted the correct seal and I have been trying to use the wrong one, but for $20 I certainly got ripped for 4 little seals and one that didnt work.
John Peacock
98 Z28 over 500rwhp
Postby FI Spyder » 12 Jan 2008 01:41
Who did you get your seals from? British Parts Northwest carries two types, Brand X and TRW. I got the TRW one for a few bucks more ($18). I've read the Brand X types are not worth the few bucks you save. I've yet to put them in but will in the next few weeks. Some kits fit more than one type of master cylinder so you don't use all the parts.
http://www.bpnorthwest.com/.sc/ms/dd/TR7-8--Braking%20Components/8084/Brake%20Master%20Cylinder%20Kit%20MGB%2075%20to%2080%2C%20TR7%20TR8
mnypitTR8
Postby mnypitTR8 » 12 Jan 2008 02:18
Yeah, I got the cheap one. It wasnt that it had more seals than I needed, it didnt have enough, and the ones that were there didnt fit. So you say the TRW works. I will have to call BPNW tomorrow.
John Peacock
98 Z28 over 500rwhp
mnypitTR8
Postby mnypitTR8 » 12 Jan 2008 03:26
OK I found the one way valve. It still seems to have the vacuum leak. I couldnt test run it too long, the wife is sleeping. I will know more tomorrow.
I shot off an email to BPNW about the quality of the rebuild kit. Lets see what happens.
John Peacock
98 Z28 over 500rwhp
terryjm1
Postby terryjm1 » 12 Jan 2008 14:03
Hey John,
Man, I wish you had contacted me a week ago. I just gave away a parts car with a functioning master and booster. The reservoir was broken though. I might be able to get it back. Email me direct.
Terry Merrell
St. Louis, MO
mnypitTR8
Postby mnypitTR8 » 13 Jan 2008 03:33
Sent you an email Terry. Let me know.
John Peacock
98 Z28 over 500rwhp
Users browsing this forum: No registered users and 177 guests
