Higher compression pistons
1980dhc
Postby 1980dhc » 18 Oct 2007 15:31
Seeing as my car in a US model, and yes I figured this out all by myself because I live in the US and I am smart like that[:D], I am assuming it has the lower compression pistons in it. I know that Rimmer Brothers out of the UK sells a higher 9.25/1 compression piston in stock bore and in some overbore sizes. How much will this improve the performance of my TR7? Also is there a better flowing head or will I have to get that done by a machine shop, and how much do the Weber DGV downdraft carbs improve performance. I of course want to improve performance on my car and I will do an engine swap, to a more modern engine, but if I can avoid it I will.
Regards,
Holt
Postby jclay (RIP 2018) » 18 Oct 2007 18:51
Look at getting a 16 valve Sprint engine or conversion kit.
A lot of people have put in the Buick V6s, which are really dependable, but just seem to kill the resale value of the cars.
trwedgn
Postby trwedgn » 18 Oct 2007 23:01
Just where would one find a sprint engine here in the US?
Postby Hasbeen » 19 Oct 2007 00:08
Holt, I have had both US, & UK spec 7s. My UK spec car has good air
filters, & richer needles, in its SU carbs, but is otherwise stock.
The difference is chalk & cheese, with the UK car at least 20% up to
25% more powerful.
The difference is over 2 seconds in a standing quarter mile, but its
in the driving that it realy shows. I have a long, moderately steep
hill out of my local town. My UK spec 7, will accelerate from 80Km
to 100Km [48 to 60 MPH] up this hill. The US spec 7 slowed from
100Km to 94Km up this same hill, on full throttle.
I also get better fuel economy from the US spec car. Probably
because I'm not on full throttle all the time.
The local Triumph guru mentioned in passing the other day, that it
was pretty easy to get 130 BHP out of the 7 engine, [cam, head job
etc] but only if you shaved the daylights out of the head. He
reckoned you needed at least 10.25 to 1 compression ratio to get
that improvement.
He also mentioned that he could find no advantage with the SU carbs
against the Zenith, US spec carbs, other than the ease of
maintenance of the SUs.
My memory of all my 10+ to 1 compression ratio cars in the 60s,
[when we had 100 octane petrol to suit them] is of cranky cars,
overheating in traffic, & being a bit of a bugger in general, but
my 9.25 to 1 TR7 is great.
PS. Check that the UK & US cams are not different. You could be
dissapointed with any improvement if the US cam is milder.
That Triumph guru uses Mitsubishi Magna pistons, with the valve
recesses machined in them, in competition 7 engines.
Postby Rich in Vancouver » 19 Oct 2007 00:15
I have a US spec car and have recently fitted a planed head, Headers, free-flow exhaust, Electronic Ignition, and 1 3/4" SU carbs with richer needles and K&N filters. The difference is noticable compared to stock. (although I have no before & after figures)
The carbs are available used from the UK and everything else is available from North American suppliers at a reasonable price.
Someone on this forum from the Eastern US had a sprint engine for sale recently. Check the archives for his post.
Richard
Postby Beans » 19 Oct 2007 23:44
...Check that the UK & US cams are not different...<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
They are the same.
Difference is in CR, ignition timing and fuelling
Postby bmcecosse » 21 Oct 2007 20:58
You should gain about 20 bhp if you fit UK pistons, SU carbs (and fettle them internally to improve the air-flow) with suitable needles and free-flow air filters. Don't 'plane' the head unless you need to!
Users browsing this forum: No registered users and 193 guests
