Solid Green Wire Flashes
HRL
Postby HRL » 03 Mar 2024 01:08
Hi All - I am getting my other TR7 out of hibernation. It has been in my garage for 8 or 9 years. (I have been driving my other TR7). I have been getting this one ready for the road. The issue I have is that the solid green wire which is a fused always on with the ignition on is getting feed back from the turn signal flasher! When I hook up my test light to the green wire the light is on but there is a light flashing when the signals are on. Even the low fuel light has a slight flashing to it. This flashing was very noticeable when I added LED daytime running lights. (Canadian car). Could this be a symptom of a bad ground somewhere or an old flasher unit?
Many Thanks for any input.
Howard
1980 TR7 DHC - Yellow
1980 TR7 DHC - Carmine Red
Re: Solid Green Wire Flashes
Postby Cobber » 03 Mar 2024 02:03
I’ll have to take your question on advise as I’m laid up in hospital at the moment and not thinking too straight a bloody heart attack will do that.
Hopefully someone will be along sooner to help you
'80 Triumph TR7.
'98 MG-F.
'83 Jaguar XJ6 Sovereign S3.
CamGTS
Postby CamGTS » 03 Mar 2024 11:04
you'll need a new electronic flasher unit that is compatible with LEDs like this https://www.classiccarleds.co.uk/produc ... king-sound
Cam
1948 Ferguson TEA20
1978 Chrysler Sunbeam 1300 LS
1979 Talbot Sunbeam Lotus
1981 Triumph TR8 (TR7V8)
1991 Peugeot 205 GTi 1.9
2004 Renault Sport Clio 182
2011 Porsche 911 GTS
2016 Porsche Macan GTS
Postby Beans » 03 Mar 2024 17:53
Cobber wrote: ... as I’m laid up in hospital at the moment and not thinking too straight a bloody heart attack will do that ...
Hi Cobber I wish you a speedy and full recovery. Take care!
Postby Beans » 03 Mar 2024 17:58
HRL wrote: ... Could this be a symptom of a bad ground somewhere or an old flasher unit?
Always a good idea to check and clean earth points. Symptoms point in that direction.
Did you also put LED bulbs in? In that case you needed an electronic flasher unit.
Postby stevie_a » 03 Mar 2024 20:15
I found these are top notch, it is a variable flasher unit, you can set the flash rate to whatever you want.
Had one in my car for a few years now.
Here
HRL
Postby HRL » 04 Mar 2024 00:51
Hi Cobber - You are dedicated to reply to this while in hospital. Take great care of yourself and lets all hope for a speedy recovery for you. All the best to you.
our weather here on the west coast of Canada is wet and snowing today, I hope you are having good weather in Australia.
Howard
(I did receive some great replies so I can start chasing down this weird issue.
Howard
HRL
Postby HRL » 04 Mar 2024 00:56
Many Thanks for all the replies! I think I know where to start looking now.
A new flasher unit is on the way and I will check any grounds I can find.
Its really cool on this forum when you get help from all over the world, even guys that are in hospital!
Shows how much we enjoy our cars.
get well soon Cobber!
Howard
