Prop shaft flange torque
jimbray
Postby jimbray » 16 Jun 2023 07:07
Hi all
I'm trying to find the torque setting for the nut that holds the prop flange on to the diff pinion, I've found the setting for gearbox end (120lb/ft) but can't find the diff end.
P.S. it's a 5 speed and it's the outer nut not the preload nut.
TIA
Jim
darrellw
Re: Prop shaft flange torque
Postby darrellw » 16 Jun 2023 10:58
According to the TR8 ROM:
Pinion flange to pinion . . . . 16 mm Nyloc nut . . . . . 160 Nm 120 lbf ft
Darrell Walker
66 TR4A IRS-SC CTC67956L
81 TR8 SATPZ458XBA406206
Vancouver, WA, USA
jimbray
Postby jimbray » 16 Jun 2023 13:16
Thanks Darrell I thought it might be the same as the gearbox end but wasn't sure.
Users browsing this forum: Google [Bot] and 28 guests
