Squeaky Bum Time.
Squeaky Bum Time.
Postby busheytrader » 06 Nov 2021 16:29
A bit of Wedge related help please.
The seat runners on the driver’s seat have developed a touch of movement front to back accompanied by a squeak. When I push down on the seat’s adjustment bar the movement disappears, so does the squeak. (The bar’s springing feels weaker than the passenger side). The movement is the same wherever the seats is positioned on the runners. It’s never been a problem for the mot test when I pointed it out.
Before I start dismantling parts, has anyone experienced this before? Is the spring likely to be broken, if not can it be re-tempered?
Thanks
irco
Re: Squeaky Bum Time.
Postby irco » 06 Nov 2021 22:19
Had similar issue with other "older" cars.
Possibly the hinge pins on the adjuster bar end sticking & needing a touch of lubrication. Aerosol lub with long straw may help the issue as a quick fix. If not a suitable tension spring shouldn't be too hard to find.
Various springs on eBay different sizes & strengths
https://www.ebay.co.uk/itm/Motorbike-Sp ... 635-2958-0
OAP Tinkerer :D
Rich K
Postby Rich K » 09 Nov 2021 12:48
I believe that there are some some small ball bearings located in the seat runner mechanism that facilitate smooth movement of the two surfaces as the seat position is adjusted back or forward. These would rely on grease to maintain their proper function and if the grease has dried out this could allow the bearings to wear or even jam. I once had a seat jam up and somehow a small ball bearing seemed to have escaped out of its “track”. I would suggest taking the seats out to inspect the condition of the runners and at the very least add some new grease.
Rich.
Ford Ranger Wildtrak
Jaguar XKR Supercharged
Postby Beans » 09 Nov 2021 22:16
Rich K wrote: ... I believe that there are some some small ball bearings located in the seat runner mechanism that facilitate smooth movement ...
That's a correct believe :wink:
But I also have seen ball bearings that were rusted solid to the seat's runners.
Lots of penetrating oil and grease solved this in one case ...
Postby busheytrader » 12 Nov 2021 20:38
Thank you guys. I’ll be looking at this in the near future
Users browsing this forum: No registered users and 271 guests
