Another body repair question....
tr7dan
Postby tr7dan » 18 Jun 2020 10:00
The seam that joins the lower front part of the rear wing to the top of the sill is a problem area but I can't quite get my head around how this is repaired. I presume the metal of the bottom part of the wing folds inward as does the top of the sill but how is this joint accessed for either drilling out the old welds or re-welding in the new repair panel ? I won't actually be doing it myself but I'm curious to know how the body shop will tackle this....
darrellw
Re: Another body repair question....
Postby darrellw » 18 Jun 2020 14:39
I assume the factory had a really long spot welder to make those joins.
On my car, I was replacing the wing, so I just cut it away. To replace, I welded in the seam, then ground back the slot to retain the look.
Darrell Walker
66 TR4A IRS-SC CTC67956L
81 TR8 SATPZ458XBA406206
Vancouver, WA, USA
Postby Beans » 18 Jun 2020 20:46
This is how the bottom of the B-post looks from the inside (LH side) ...
tr7dan
Postby tr7dan » 19 Jun 2020 23:16
Ok, thanks for the replies - Beans, I fear mine won't look anything like that inside :( :)
Postby dursleyman » 30 Jul 2020 16:29
Had to get the bodyshop to do both sides on my car after I bought it some years ago, this is what it looked like with the bottom of the wing cut out.
They fitted the readily available repair panels and the finished result looks good and you can see the before picture as well..
L IMG_0016 b.jpg (143.9 KiB) Viewed 6948 times
Users browsing this forum: No registered users and 19 guests
