Starts then dies help
Mmoodd
Postby Mmoodd » 01 Apr 2020 11:54
Al I have done is fit new battery
Engine fires then dies ie won’t idle
If I keep key turned ie starter circuit engaged it revs ok then as soon as key released it dies
Cursory checks all seems ok ie fuel at in line filter near carbs nothing obviously come adrift or disconnected
Any comments ideas welcome to start my faultfinding process
Everything worked fine before battery change which may just be a coincidence
1981 tr7 convertible su carbs no modifications other than electronic ignition petronix
seven
Re: Starts then dies help
Postby seven » 01 Apr 2020 13:03
Mmoodd wrote:Al I have done is fit new battery
If you have a ballast resistor this could be at fault?
Dodge Dakota 4x4 '05
Triumph TR7 DHC '81
Triumph 2.5 Estate '73
Triumph 2.5PI Saloon '69
Triumph Herald 12/50 '65
Mercedes SL55 AMG '02
Mercedes E320 '05
Mitsubishi Canter '01
Rolls Royce Silver Shadow '76
Fiat Ducato Motorhome '03
Postby Cobber » 01 Apr 2020 13:33
Yeah this has a dead ballast resistor written all over it!
'80 Triumph TR7.
'98 MG-F.
'83 Jaguar XJ6 Sovereign S3.
seven
Postby seven » 01 Apr 2020 13:36
Cobber wrote:Yeah this has a dead ballast resistor written all over it!
Great minds think alike Cobber :lol: :lol:
Triumph TR7 DHC '81
Mercedes E320 '05
Mmoodd
Postby Mmoodd » 01 Apr 2020 16:20
Thanks for that
How do I locate the resistor to check it/ replace ?
Is it behind the dash
Postby Beans » 01 Apr 2020 16:34
I'd start with a thorough check of the ignition switch.
Postby saabfast » 01 Apr 2020 16:53
Assume the 'ballast resistor' noted is the 'eureka (resistance) wire' which drops the voltage to the coil to around 8V? The car starts on 12v from a start ignition switch contact and the drops to 8V for the 6V coil when it is released. However, I would agree with Beans to check the switch as they have a reputation for contact failure. If the 'running' contact is bad it will not put power through the eureka wire to the coil.
Mmoodd
Postby Mmoodd » 02 Apr 2020 14:55
Thanks for all your advice checked through and located fault to starter relay
The relay was changed a month ago for new from Rimmers inter motor part
With nothing to loose I opened up the old Lucus relay and found solder to coil adrift resoldered and it worked
Refitted old relay and she fires ok
Fault returns when new intermotor relay refitted
Rimmers sending another one
Once again thanks until the next time
seven
Postby seven » 02 Apr 2020 21:27
Mmoodd wrote:Thanks for all your advice checked through and located fault to starter relay
Glad to hear you got it sorted, I'd never have guess a relay :oops:
Triumph TR7 DHC '81
Mercedes E320 '05
Mmoodd
Postby Mmoodd » 03 Apr 2020 08:43
Yea my interpretation looking at the wiring diagram tho I may be wrong is that the feed to the eureka wire is thro the relay
When the start key is engaged the start coil pulls in and then fires the starter motor
On release the normally closed contact then feeds the coil
Presume those contacts have failed
