TR7 Water Pump - Davies Craig EWP80
John Houston
Postby John Houston » 15 Mar 2020 03:14
So I installed the Davies Craig EWP80. I love this thing! Kicks on after shutdown and cycles water through the head to eliminate heat soak. Makes pulling the intake manifold easier. AND, the loud resonant vibration that came from the engine between 3,300 and 3,800 rpms is now GONE! It ain't as quiet as a Prius, but it's close. If you've been thinking about it, just jump in. Oh, and the heater still works too!
Re: TR7 Water Pump - Davies Craig EWP80
Postby rugbyref1 » 16 Mar 2020 08:02
Never hear of it … how does it fit?
Davies Craig EWP80.jpg (12.15 KiB) Viewed 7850 times
Christopher
oliviertr7
Postby oliviertr7 » 16 Mar 2020 08:52
john Houston: do you have pictures of the assembly on your tr7?
Postby Cobber » 16 Mar 2020 09:06
I've been recommending these things for years, fitted one to a mate's 32 Ford roadster hotrod running a 429 Ford V8 (7.0 litre) a bloody good piece of kit. I've got one for my 73 landrover running a 351 Ford Cleavland V8 (5.8 litre)
That is if I ever get around to finishing it.......who knows I might end up with it in the TR yet!
Mounting is simple, you just cut a section out of the bottom radiator hose and then insert the pump between the hose ends. Then remove the thermostat, set up the wiring, temp sender etc.
For most cars with a conventional mechanical water pump, the impeller can be removed from the shaft of the old pump and the old pump housing will provide the connection spigot for the bottom hose. But it's possible to do away with the pulley, shaft and water pump housing if it is advantageous for your installation by fabricating a new lower spigot housing to bolt on where the old water pump lived.
Our cars (2.0 4cyl) however do not have a conventional water pump set up. I can't remember the details but it is still possible to fit these EWPs to our cars There is a Dolomite Sprint specialist in Sydney who does it, it might be possible to source the required bits from them.
'80 Triumph TR7.
'98 MG-F.
'83 Jaguar XJ6 Sovereign S3.
Postby saabfast » 16 Mar 2020 12:45
I think there was a thread on the old forum regarding fitting these pumps. Someone was making a plug to blank off the existing pump opening on the TR7 engine if I remember correctly.
If it is fitted in the bottom hose and the thermostat removed how does it control the engine temperature? Would it not run too cold?
darrellw
Postby darrellw » 16 Mar 2020 13:12
saabfast wrote:If it is fitted in the bottom hose and the thermostat removed how does it control the engine temperature? Would it not run too cold?
Thermostatically controlled switch for the pump.
Darrell Walker
66 TR4A IRS-SC CTC67956L
81 TR8 SATPZ458XBA406206
Vancouver, WA, USA
Postby Cobber » 16 Mar 2020 13:30
It has an electronic controller that adjusts the pump speed according to engine temp.
For more info here is Davies Craig's site: https://daviescraig.com.au/
They have been making thermatic cooling products since the early 70s, we used their thermatic fans in our race cars back in the early 70s and have used them since.........absolutely reliable, never had any trouble with them and I've found them very approachable and and helpful when ever I've had technical questions.
'80 Triumph TR7.
'98 MG-F.
Postby Cobber » 16 Mar 2020 13:47
It gets a mention Rodger Williams book :How to Improve Triumph TR7, TR7-V8 & TR8 https://books.google.com.au/books?id=sojVCQAAQBAJ&pg=PT542&lpg=PT542&dq=davies+craig+tr7&source=bl&ots=6uaWv5JoMm&sig=ACfU3U1Jx_sgN9iLPr2a9HL_8faBSXXa7A&hl=en&sa=X&ved=2ahUKEwiW956ck5_oAhVD6nMBHYL8CowQ6AEwDHoECAkQAQ
I now seem to remember that the Dolemite specialist was called Spintparts
'80 Triumph TR7.
'98 MG-F.
Postby saabfast » 16 Mar 2020 14:39
Cobber wrote:It has an electronic controller that adjusts the pump speed according to engine temp.
That makes more sense than an on/off sensor, would not like to stop the flow through the engine! Have to admit I have not read that book for a long time.
Could not find the previous thread - was there not an archive somewhere?
Postby Beans » 16 Mar 2020 19:54
Sprintspeed do a conversion set to fit this pump to a slant 4 engine
2020-03-16 Craig Davies EW80.jpg (147.76 KiB) Viewed 7823 times
Stag76
Postby Stag76 » 19 Mar 2020 08:15
I silver soldered brass plates on the top and bottom of the existing pump cage, and used core plugs
to block the holes in the manifold and pump cover.
The existing heater returns to the pump cover, which works because this is a low pressure point when using the
mechanical pump. When the EWP is used the entire block is pressurized, so the heater return will not flow. To get
around this, I tee'd it into the pipe that connects the radiator to the header tank.
It is easily the best mod you can do to a Slant 4.
simps
Postby simps » 05 Apr 2020 13:26
Interesting topic...
Did you use the controller as well or simply rely on the pump as a stand alone?
Stag76
Postby Stag76 » 15 Apr 2020 10:25
I Used the Controller...it replaces the thermostat.
This allows you to set the temperature that you want the engine to run at, and
it turns the fan on when the engine is 3 degrees above the set temp., and turns it off
when it drops to 2 degrees below the set temperature. The fan would only come on after 10-15
minutes idling in traffic in warm-hot weather, and then only run for approx. 3 minutes.
It also allows you to run the pump for a specified time after stopping the engine, or
until it drops to a certain temperature.
