Triumph TR7 boot / trunk lock
supercass
Postby supercass » 26 Sep 2019 17:16
Anyone know how to remove the locking mechanism from the plastic surround on the boot (or trunk) lock?
sipercass
Postby saabfast » 26 Sep 2019 18:36
Covered on page 277 of the manual assuming the early type lock.
(Sorry, can't seem to insert the image).
Re: boot / trunk lock
Postby Beans » 26 Sep 2019 18:57
Twist or press lock release?
supercass
Postby supercass » 26 Sep 2019 19:53
Apologies for not making it clear. The late type push button lock. It isn't immediately obvious how it is separated.
supercass.
Postby Beans » 28 Sep 2019 23:36
Can't help with the push button lock.
I did install one to my DHC, but didn't have to dismantle it :roll:
trsforever
Postby trsforever » 02 Oct 2019 06:49
Hi, with the boot lid open there are 2x access holes either side of the lock from one off these holes with the flat blade of a screw driver you will be able to get contact with a large thin metal spring "C" clip that holds the lock in place, it has a folded up part on the clip to push against. Have a look at page 92 rimmers catalogue part # 723290A YKC4530 looks the same for both lock types. Good luck hope this helps.
supercass
Postby supercass » 02 Oct 2019 21:02
Thanks for reply. I have already removed the lock from the boot. It is separating the locking mechanism itself from the round black plastic escutcheon that I am struggling with.
supercass
trsforever
Postby trsforever » 03 Oct 2019 04:35
Hi Sorry about that, my lock has a small screw in the end that holds the white plastic locking part to the key barrel but it does look like its been modified! My factory manual only covers early twist locks, but if you push the button all the way in there are 2x small metal clips either side its possible they hold it together? but they could also be what holds the individual lock tumblers in place?? sorry I can't be of more assistance.
Peter Nuss
Re: Triumph TR7 boot / trunk lock
Postby Peter Nuss » 09 Nov 2019 04:32
Push the lock button in to the housing until it stops. Then you will see two little metal pieces sticking into the sides of the white plastic button. Pry those off with a little screw driver. The button will then pop out when released.
TR8
