Triumph TR7 subframe drain holes
supercass
Postby supercass » 22 Aug 2019 18:39
Where are the drain holes on the subframe? I've sprayed about 250 ml of thin rust protection oil in mine and only about 1/10th of that has come out!
supercass
johnnyj
Re: Triumph TR7 subframe drain holes
Postby johnnyj » 22 Aug 2019 21:36
Hi Cass
I am not sure that there are any. Here's a photo of the top and underside. Lots of holes, but once used up by the steering rack, engine mounts etc I am not sure what's left over.
TR7 Subrame draining holes.JPG (54.2 KiB) Viewed 5430 times
TR7 Subrame drain holes.JPG (57.57 KiB) Viewed 5430 times
Triumph TR7 FHC, 1977
http://t-r-7.blogspot.co.uk
supercass
Postby supercass » 23 Aug 2019 09:03
Hi John,
Thanks for your reply and photos's. Have to keep an eye on this. It could be full of water. Not surprising they go rusty!
supercass
Postby FI Spyder » 23 Aug 2019 15:06
You see the four holes in the bottom. As the picture shows the mount upside down, these are at the low spots. It's a good thing that only a little came out as that means most of it is inside where it can do some good. I also sprayed waxoil in through the two holes in the front of the car to coat the inside of the inner and outer fenders. You could see the fog coming out of the two holes (square drain plugs first removed) behind the front wheel wells. I used waxoil cut with turpentine (used the low odor stuff, I used the cheaper regular stuff and it was pretty smelly for a while) to cut it and an engine cleaning spray wand hooked up to air pressure.
REX
Postby REX » 25 Aug 2019 10:24
Hi Guys, I have been reading your posts for sometime and they have proved very informative, so perhaps I can add a little to this question. The four irregular holes in the centre bottom of the subframe are the drain holes. If you feel round inside each hole you will feel reinforcing vertical strips. These vertical strips continue throughout the subframe and give it it's rigidity. Without these the subframe would bend. As these are separated, rust preventer can be sprayed in. My experience is with TR8 subframes but it should not be any different to the TR7 one.
Postby dursleyman » 27 Aug 2019 15:08
They sure do go rusty, I had to change one about two years ago. Doing a bit of poking about on my DHC and found this lot.
Triumph TR7 subframe - rusty.JPG (62.4 KiB) Viewed 5322 times
Triumph TR7 subframe - rusty 1.JPG (75.07 KiB) Viewed 5322 times
Triumph TR7 subframe - rusty 2.JPG (86.19 KiB) Viewed 5322 times
Postby FI Spyder » 28 Aug 2019 16:04
Mine looks almost new but there is a little rust at the edges where the paint seems particularly susceptible to road grit as are other parts down there for the same reason. It's been over twelve years since that stuffs been out, hopefully this winter I can get the car in (and the Tercel resto out) to pull the suspension, check the shocks, and do the rear as well. I think the rear Koni's (that have been in the car over 20 years) are making some noise and may be time to change them.
Users browsing this forum: No registered users and 85 guests
