Lumenition IGNITION
swordfishdani1960
Lumenition IGNITION
Postby swordfishdani1960 » 07 Aug 2019 15:45
hI I Have attained this system ,and it has no wiring gram
its for delco distributor,which i have as well .as i can see in the distributor
there is an eye system ,this connects to a plug ,that remains the cables
left Black, Brown, Red .so i assume that Blacks Earth. reds ignition Brown coil
i received the coil as well and the Brown cable has a spade clip on it .so does the coil
negative side This came out a Tr7 ,can any body help in the installation of this .,
most great full
Re: Lumenition IGNITION
Postby busheytrader » 07 Aug 2019 18:00
Hopefully this helps......
https://autocar-electrical.co.uk/images ... -hints.pdf
I've had Lumenition Optronic on my V8 for about 28 years and no issues, although others here have had problems.
Postby Beans » 07 Aug 2019 21:57
Is the coil 6V or 12V?
swordfishdani1960
Postby swordfishdani1960 » 07 Aug 2019 22:11
12 volts
Postby Beans » 08 Aug 2019 18:38
In that case you have to bypass the ballast wire in the loom, otherwise you'll only get 6V at the coil
Postby Hasbeen » 09 Aug 2019 08:06
It was the Lumenition ignition system on my 7 that gave me my worst headache in my 17 years with the car.
It would become very mildly hesitant on small throttle openings in the first 3 or 4 kilometres of a drive. It would never show a fault by the time I got to town, & a good auto electrician. I could not decide if it was a fuel or ignition problem.
Each time I cleaned everything, replaced wires, changed from bayonet fittings to ring end fittings bolted tight or any other attempt to find the fault it would be fine for a few months, then revert.
It was only when it went to cutting the engine for a second or so that we found the fault.
Hope you don't have such a problem.
Maki
Postby Maki » 09 Aug 2019 12:28
I had this on my V8, however, it caused many a headache. In the end I sent it back, they said it was fine but it clearly was not as I replaced it with a Powerspark distributor and the car has never run better!
swordfishdani1960
Postby swordfishdani1960 » 13 Aug 2019 08:45
Had a look for the BALLAST RESISTOR CAR DOEST HAVE ONE
MY COIL IS WARM ,AND HAS 12 VOLTS ON IT WHEN RUNING
CARS PRE 77/ IS THIS THE NORMAL
Postby Beans » 14 Aug 2019 18:35
It is not! Though the coil will get warm during operation
swordfishdani1960
Postby swordfishdani1960 » 16 Aug 2019 12:33
Well the coil has been in the car since new would say its lasted well
and the cars a 1977 ,they now dont make parts like they used to
all shit now from china ,and the uk is going to follow suit
Postby Beans » 17 Aug 2019 00:54
I have been using Bosch 6V coils for as long as I drive my TR7's (since 1988), never had any problems
How did you measure the voltage @ the coil?
