Wheel Hub Upgraded Bearings
Sondar
Postby Sondar » 22 May 2019 08:38
Hi All,
Anyone know if it is possible to modify the standard front wheel hubs to take larger / stronger bearings? Standard bearings just seem to be made of chocolate (or something softer), and the torque setting is a pain in the proverbial.
I think I recall seeing that you can put SD1 hubs on instead, but I want to keep the PCD and the AP brakes, so that won't work for me.
Sondar
1980 TR7V8 in Poseidon Green - 4.6 Rover V8, limited slip diff, front coil-overs, AP Racing 4-pot front brakes, leather interior. Last of 8 owners, mine since 1999 and no-one else is getting it...
darrellw
Re: Wheel Hub Upgraded Bearings
Postby darrellw » 22 May 2019 14:15
TS Imported Automotive will convert your hubs for larger bearings, so it is possible:
http://www.tsimportedautomotive.com/tr7_tr8.html
Big front wheel bearing kit - replaces small outer wheel bearing with a larger bearing. This keeps the hub from distorting. Kit includes modified hub, new inner and outer wheel bearings and seals. Price is exchange. 2 required.
Darrell Walker
66 TR4A IRS-SC CTC67956L
81 TR8 SATPZ458XBA406206
Vancouver, WA, USA
Postby Beans » 22 May 2019 21:05
Not worth the money, just buy good quality bearings.
And make sure they are fitted correctly and check on a regular basis.
Sondar
Postby Sondar » 23 May 2019 00:32
Thanks for the replies guys.
Easy to say Beans, not always easy to find good quality bearings. Any suggestions on manufacturer to chase down?
Sondar
Postby Hasbeen » 23 May 2019 01:36
Beenleigh Bearings, southern Brisbane suburb, have all the best bearings. They were the only people who could tell me what was wrong with my flywheel, causing my clutch to not release properly, & can supply almost anything, due to the knowledgeable people there.
I have no idea if they do mail order, but worth a try. They supplied all my new bearings 17 years, & 73000 kilometres ago for the 7, & they are still smooth & silent.
Postby Beans » 23 May 2019 20:35
Sondar wrote: ... Any suggestions on manufacturer to chase down?
SKF or FAG. Both can supply the necessary bearings
kstrutt1
Postby kstrutt1 » 23 May 2019 21:35
Mines fitted with a V8, and 195 15 tyres, in the last 25 years it has done 100,000 miles and I have never changed the bearings, when I had the hubs off to change the discs recently they looked fine, as said above use a known make of bearing from a reputable source (lots of knock off parts on ebay , Amazon etc) and good quality grease and they should be fine.
Postby busheytrader » 25 May 2019 12:14
Or for £495 + carriage to the other side of the world ......
http://www.hamilton-motorsport.co.uk/ac ... ubs%2ehtml
+1 for going the quality bearing route. On the Mini Forum there's multiple posts from those who've fitted cheaper wheel bearings from eBay or Amazon and not invested in Timken items. I coughed up for Timken and hopefully it'll be proved right when the Mini eventually returns to the road.
Sondar
Postby Sondar » 27 May 2019 04:24
Thanks Guys; appreciate the help.
Sondar
Users browsing this forum: Google [Bot] and 36 guests
