Fuel gauge late is full
syol
Postby syol » 18 Feb 2019 19:13
the fuel gauge always indicates full, I change the gauge of the tank, change the gauge of the dashboard, always the same result.
Do you have an idea ?
Thank you
TR8 V8 3,5L 1980
TR7 DHC 2.0L 16s
3 tr7 DHC 2.0 L 1980
TR7 FHC and sunroof 1981
http://www.tr7.fr
Re: Fuel gauge late is full
Postby Cobber » 19 Feb 2019 01:38
Maybe its just optomistic........ :lol:
It will have to be a problem with the wiring.
'80 Triumph TR7.
'98 MG-F.
'83 Jaguar XJ6 Sovereign S3.
Rich K
Postby Rich K » 20 Feb 2019 19:54
Hi, it could be due to a break in the green and black wire that runs from the sender in the tank to the fuel gauge. Check the continuity of this wire. It is also possible (although unlikely) that the new gauge is also faulty.
Ford Ranger Wildtrak
Jaguar XKR Supercharged
skertonman
Postby skertonman » 20 Feb 2019 21:27
Wire that goes to sender unit shorting to earth somewhere, that would be my guess.
Only trouble now is finding out where, I would start at the back (tank) and work forward.
syol
Postby syol » 24 Feb 2019 09:02
Hello, thank you for your answer, I tried to put the ground wire directly to the battery ... I always have the same result
TR8 V8 3,5L 1980
TR7 DHC 2.0L 16s
http://www.tr7.fr
