Spire clips
johnnyj
Spire clips
Postby johnnyj » 21 Dec 2018 09:15
Hi folks. I am trying to find some replacement clips for the interior trim on my TR7. I think they are called spire clips and the ones I am looking for are used to hold the thick sound deadening mats to the front bulkhead. They're a little square thing with four holes in addition to the centre one; a push fit over a pin on the bodywork.
I'll try to find a part number, but I think they are unavailable from the usual suppliers. Anyone know if they can be found anywhere, or is there is an alternative? Perhaps an innovative enthusiast has found a solution already!
Many thanks
Triumph TR7 FHC, 1977
http://t-r-7.blogspot.co.uk
Re: Spire clips
Postby saabfast » 21 Dec 2018 16:02
As far as I know 'spire clips' are the clips which fit over the edge of a panel with hole in it to allow fixing with a screw. Those look like insulation mechanical fixing pins, otherwise known as 'Stick pins', like:
https://www.insulationexpress.co.uk/ins ... f-adhesive
Lots of suppliers if you google it. Not sure where you can get them that small though.
Edit: These are a bit smaller but looks like you need to buy 500!
https://www.adafastfix.co.uk/Products/Stick-Pins/SPIN45
Also on ebay in smaller quantities but a bit longer:
https://www.ebay.co.uk/itm/62mm-stick-p ... :rk:2:pf:0
Might be easier to use self adhesive AV pads and insulation these days.
Steve @ SandS
Re: Spire clips
Postby Steve @ SandS » 21 Dec 2018 19:15
You've obviously not tried the usual suppliers :D
Steve @ S&S Preparations
www.ss-preparations.co.uk
johnnyj
Re: Spire clips
Postby johnnyj » 21 Dec 2018 20:03
Ha! Steve, you're gonna tell me you have them :) I should have called you.
While you're at it, do you have a RHD front bulkhead moulded sound deadening panel thingy?
johnnyj
Re: Spire clips
Postby johnnyj » 22 Dec 2018 10:10
saabfast wrote:As far as I know 'spire clips' are the clips which fit over the edge of a panel with hole in it to allow fixing with a screw. Those look like insulation mechanical fixing pins, otherwise known as 'Stick pins', like:
Hi Alan, thanks so much for going to such lengths for me! I think you are on the right track here, so I'll continue to dig deeper. If I come across a solution, I'll let you know. Likewise I'll see if Steve has any!
All the best
Re: Spire clips
Postby Beans » 22 Dec 2018 19:33
If you're trying an online search, you're looking for part number ZKC991 (fixing clip)
