Front Shock Gaiter Fitment
bonnietiler
Postby bonnietiler » 24 Oct 2018 09:59
Now I'm going to rebuild my front shocks, generally tart them up a bit (technical term)
On having a looksee at the schematics it seems that we fit the Gaiter to the top feed it through the spring and squeeze it over the bumpstop and the damper nut and fasten with a cable tie...
It looks a little tricky as you haver little room to accomplish this
Is there a cunning TR7 Forum wheeze to finish this job?
Any help much appreciated
Brian
Re: Front Shock Gaiter Fitment
Postby saabfast » 24 Oct 2018 12:32
Sorry to say that, from memory, that's just about what I did. Fiddly but not too bad really.
Postby dursleyman » 26 Oct 2018 17:15
I did mine recently and it was a bit of a fiddle. Took me several goes to sort it out. From memory I had to feed it down through the spring with the bump stop inside and fit the cable tie on the strut body. Then it was possible to assemble the top bearing etc and persuade the gaiter to go into that little groove on the upper spring mounting.
Not easy, but I expect the usual experts will say its a piece of cake!
Postby FI Spyder » 28 Oct 2018 15:40
Fiddley pretty much describes it. Handy to have a spring hook and hemostat, two of the most important and often used tools in my tool kit.
MikeRotherham
Postby MikeRotherham » 01 Nov 2018 14:43
I used one of these when I did mine.
https://www.ebay.co.uk/itm/Wooden-handl ... 2508236991
I fastened the gaitor at the bottom with the cable tie then used the hooked tool to locate the top of the gaitor onto the recess at the top of the strut. Then keeping the tool under the lip of the gaitor pull the tool around the circumference of the recess and ease the remainder of the gaitor into the recess. Hard to explain in words.
If your wife or mother has made rugs in the past they may have one you can borrow
Users browsing this forum: No registered users and 43 guests
