Ignition light
swordfishdani1960
Ignition light
Postby swordfishdani1960 » 15 Oct 2018 06:57
My ignition comes on and flashes of and on .all is good battery getting charged 14 47 volts
wires are all good no bad earths or rusty connections ,any thought s
Re: Ignition light
Postby dursleyman » 15 Oct 2018 13:09
Sounds like it might be the alternator diodes playing up before they fail altogether?
Re: Ignition light
Postby FI Spyder » 15 Oct 2018 15:23
Not had it happen on TR7 but on my Integra the ignition light would come on often even though voltage reading was good and never had a problem with battery. There was a vampire drain in the system at .3 amps which meant when I left the car for three or four days the battery would be flat. I had sprayed the ignition switch with graphite and it was conducting a current when the switch was off (and presumably interfering with the ignition light balance circuitry). I flushed out the graphite in the ignition switch with silicone spray and the vampire drain stopped and the ignition light didn't come on. I would spray the ignition switch with silicone working it back and forth and see if that fixes the problem. Can't hurt and is probably something that should be done anyway.
